noise and cant find problem sloving.
1996 EJ25 dohc 208K
when i was replace o-ring of fuel injection...
somehow got bad noise...
VVVVVVVVVVVVVVVVVVV
so, im decide pull out the engine and see nothin damage bore and pinions.
VVVVVVVVVVVVVVVVVVV
i dont understand why and i dont want put engine on it and get noise again.
please help me.
Rod knock, even when you spin it by hand I hear it. I think.
I belieive it is much more common in these engines than any enthusiast would like you to believe.
I hope the rebuild market has figured out how to cost-efficiently build thee bottom ends. It's not something I can spend the time learning.
So what normally causes it? Worn out rod bearings or are the caps stretching?
I believe it is normal to reusing rods and caps in rebuilds, with undersize bearings and a crank grind if necessary. Out of round journals are the most likely culprit, IMO. The 2.5 pack quite a punch on a short stroke.
Splitting and re-splitting the cases and "plastigage"-ing the journals seems like a half-baked way to rebuild these. It would either take some crazy high tech micrometers or a perfect touch , neither of which I have.
With the case bolts threaded into aluminum, the bolt stretch may have to be done merely by expert hand.
mmm, Im still dare get one new rod before installed. I need Try to sell it.
only used 50miles of Fel-Pro head gasket.
old piston and rod's bearing.
96' Ej25 DOHC is old sh*t...
you think Ej22 can fit with automatic from Ej25? doubtfully...?
Edited by Suba_GL_87
