Mike,
You're kidding right?
A 95 2.2 AUTO!!! is preferred because your Ypipe will work. (MUST HAVE EGR).
96, 97, 98 will work but you'll need the single port Ypipe from that engine.
As usual a littel rubber hose plumbing work for VC breathers and maybe EVAP.
I was thinking the same thing as Dave - you're kidding right?
You didn't mention what years as there are different phases but we can infer since you didn't question dave that you're talking about a 96-99 Outback.
95 automatic
or
96-98 with a single port ypipe and make sure the engine has EGR
there is no rhyme or reason to 96-98 having EGR or not, but most that i see around here do have EGR so lots of easy 96-98 options too.
Okay try to be a little easier on this old guy. I didn't put the year and you were both correct.
Thanks
oh yeah wasn't being hard at all...no poking meant at all, was genuinely surprised so i wasn't sure how to answer since i assumed you knew those swaps.
