turbosubarubrat Posted October 26, 2012 Share Posted October 26, 2012 the low beam is not working on my 1985 brat but the high beams work great, i have tried useing a different switch but still the same, so what do you guys think it is? a bad wire or connection? i check some of the fuses and one was blown but it was for the tail lamp for license plate so no difference i can check the rest but i checked the obvious like the head light fuse, it hasn't been run since the engine was put back in so could it be a blown fuse link? Link to comment Share on other sites More sharing options...
edrach Posted October 26, 2012 Share Posted October 26, 2012 the low beam is not working on my 1985 brat but the high beams work great, i have tried useing a different switch but still the same, so what do you guys think it is? a bad wire or connection? i check some of the fuses and one was blown but it was for the tail lamp for license plate so no difference i can check the rest but i checked the obvious like the head light fuse, it hasn't been run since the engine was put back in so could it be a blown fuse link?Not to be a pest, but have you checked the bulbs? It wouldn't be the first time both bulbs were out. If it was both bulbs, check the alternator output at 3500 rpm; if the voltage is above 14.8V the alternator is burning out your low beams because they are most susceptible to premature burnout at high voltage. Link to comment Share on other sites More sharing options...
ShawnW Posted October 26, 2012 Share Posted October 26, 2012 I'm with Ed on the bulbs. Link to comment Share on other sites More sharing options...
