Help with Sedan EA82. Can't remove plastic cover...
  • 2 weeks later...
I went by the yard today and had an opportunity to remove a couple of these back window trim pieces. And it is true that you need to slide the trim piece upwards to unlock and remove. But, first you must pop the lowest fastener loose the same way you pop a door panel fastener loose. Then the whole trim piece can easily be slid upwards and removed.
Curious, what did it cost you?
Thank you so much, now I just have to cross my fingers and try it on mine
