MAP sensor and the pressure sources switching solenoid. The solenoid allows either engine vacuum or atmospheric pressure to the MAP sensor. You'll get codes for them if you bypass them, and may get poor driveability. Best to leave them alone. If the vacuum hoses are damaged, cut, etc. replace the hoses.
