someone kill me please. ej25 issue
The block won't split for me :( I found pics and I have gotten all of the block halve bolts, and I have removed the pistons. What's going on??? Just a stubborn block???
I know you say you got all of them, but did you get the 12mm under the rear main seal and the 10mm in the oil pan area?
i hate to repeat but make sure you didn't miss one bolt, it's so common to think you got them all then find out you didn't.
if i can't get a block to separate on easier terms i use a 2x4 against some part of the block and wail on it with a hammer. that's worked every time so far.
tie one end down securely then use a come along or winch on the other side, that should do it. LOL
