ivans imports Posted November 14, 2012 Share Posted November 14, 2012 was able to rebiuld a expanded awd five speed center diff was able to press it apart and reinstall the clutchs and plates and wire seperators. I thought it was a non rebiuldabble part but it seems to be fixabble. The trans had lost the awd output berring that ruind the front awd berring and that alowded the gear to grab the snap ring and tear it out then awd expanded and came apart. was a mess inside but was repairablle and go's back in today see how it works. The cool thing is that you could modify the awd to make it stiffer or more or less responsive by adding or removeing plates or viscus fliud Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 14, 2012 Share Posted November 14, 2012 was able to rebiuld a expanded awd five speed center diff was able to press it apart and reinstall the clutchs and plates and wire seperators. I thought it was a non rebiuldabble part but it seems to be fixabble. The trans had lost the awd output berring that ruind the front awd berring and that alowded the gear to grab the snap ring and tear it out then awd expanded and came apart. was a mess inside but was repairablle and go's back in today see how it works. The cool thing is that you could modify the awd to make it stiffer or more or less responsive by adding or removeing plates or viscus fliud did you put in new fluid? where did you get it? I THINK I once read an article or maybe watched a video(Australian source IIRC) about testing and modifying those viscous units. A guy had one chucked in a lathe and was testing/measuring it with some kind of torque wrench. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 14, 2012 Share Posted November 14, 2012 Yeah they should have special fluid. I believe it's silicone based.... Also note that this only works with the 99+ VC's. The older one's are welded together and can't be opened without destroying them. GD Link to comment Share on other sites More sharing options...
ivans imports Posted November 16, 2012 Author Share Posted November 16, 2012 works very well i took care to not disturb the factory fliud had not come out yet the diff had just poped apart. Not far enuff to loose the viscus fliud may have lost a tiny bitt. But its my belif that a bitt less fliud will make it last longer as they have a problem with overheating and expanding till it pops apart. anyway the awd works perfectly and i torture tested it no slips and awd is right there Link to comment Share on other sites More sharing options...
torxxx Posted November 17, 2012 Share Posted November 17, 2012 Is the 99 VCD swappable into the earlier 5 speeds? I keep hearing about welding up the center diff, but if the older style is not openable I dont see how people are welding them. I dont remember the board members that have done it, but I've seen it come up in some conversations on the forum Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 17, 2012 Share Posted November 17, 2012 Is the 99 VCD swappable into the earlier 5 speeds? I keep hearing about welding up the center diff, but if the older style is not openable I dont see how people are welding them. You would have to swap the entire transfer case. You don't have to weld the VC itself. You just weld it to the spider gears so no differentiation can occur. GD Link to comment Share on other sites More sharing options...
torxxx Posted November 18, 2012 Share Posted November 18, 2012 ahh ok I gotcha. Thanks GD! Link to comment Share on other sites More sharing options...
ivans imports Posted November 20, 2012 Author Share Posted November 20, 2012 have mixed and macthed them but like gd says have to use the whole back half the front case and parts are the same have fixed many 5 speeds. I find they break alot more than the autos do 10 5speeds for evry one auto i do. The awd overheats if driven at to high of speed for to long or differnt tires or uneven tire preshure. And lots of main shaft support berrings or run low on oil I must be at 5 speed # 12 for thiss year Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 20, 2012 Share Posted November 20, 2012 I agree they are not nearly as reliable as the Automatic's. A lot more fun though! GD Link to comment Share on other sites More sharing options...
ivans imports Posted November 21, 2012 Author Share Posted November 21, 2012 fun is a 79 wagon with a 09 sti engine and 5 speed high low havent driven it in while but after driving a justy around is a bitt more fun and mabee a few more hps than my 1.2 auto justy lol Link to comment Share on other sites More sharing options...
