mojoman Posted November 17, 2012 Share Posted November 17, 2012 vin# 4S3BG6854V7629590 ....need to know what month it was built....thankx folks...) Link to comment Share on other sites More sharing options...
the_bard Posted November 17, 2012 Share Posted November 17, 2012 (edited) According to here: http://www.edmunds.com/driving-tips/making-sense-of-your-vin.html ... and if I can count, the tenth digit is a V, making it a '97. Oh, wait... you need month. Hold on. Is there any reason you need it specifically from the VIN? It should be on the door jam sticker, if I remember correctly. Edited November 17, 2012 by the_bard I'm an idiot. Link to comment Share on other sites More sharing options...
porcupine73 Posted November 17, 2012 Share Posted November 17, 2012 Hm not sure if Ca. spec was the same, but I think the US vehicles had the build date on one of the placards inside the drivers door panel ... Link to comment Share on other sites More sharing options...
mojoman Posted November 17, 2012 Author Share Posted November 17, 2012 was a split year for the '97's for the plug wires...I'll check out the door panel...thankx budz!!! Link to comment Share on other sites More sharing options...
avk Posted November 17, 2012 Share Posted November 17, 2012 The build date used to be on the VIN plate and a 1997 should have it. At some point, they stopped putting it on the plate. Link to comment Share on other sites More sharing options...
johnceggleston Posted November 17, 2012 Share Posted November 17, 2012 the build date used to be on a sticker on the B-column, like the tire pressure sticker. then they moved it. at one time is was on the bottom of the drivers door. look there. Link to comment Share on other sites More sharing options...
ivans imports Posted November 17, 2012 Share Posted November 17, 2012 if you look at valve cover one says twinn cam other is blank twinn cam stamped ones are hydrolic lifters and female coilpack in 97 whent to female coil and nohydrolic lifters in 98 they whent to male coil and nonhydrolic lifters is a pain have 4 diferent wire sets in 4 years and to add to it its listed as a legacy outback parts guys never mess that up Link to comment Share on other sites More sharing options...
johnceggleston Posted November 17, 2012 Share Posted November 17, 2012 if you look at valve cover one says twinn cam other is blank twinn cam stamped ones are hydrolic lifters and female coilpack in 97 whent to female coil and nohydrolic lifters in 98 they whent to male coil and nonhydrolic lifters is a pain have 4 diferent wire sets in 4 years and to add to it its listed as a legacy outback parts guys never mess that up right? Link to comment Share on other sites More sharing options...
Wayback Posted November 17, 2012 Share Posted November 17, 2012 1997 Legacy Outback AT. Unfortunately my production chart ends 11/96. Starting number for this model in that month was 622039, and the previous few months increased 4000-6000/mo, so I would guess yours was built 01/97. Link to comment Share on other sites More sharing options...
987687 Posted November 18, 2012 Share Posted November 18, 2012 VIN check says it was first registered in 03/21/1997. But it didn't necessarily get bought as soon as it hit the lot. VIN reports don't give the month of manufacture, at least, not the way I get them... Also, wow. That car went from the east coast of Maine, to BC. And not registered anywhere in between. Link to comment Share on other sites More sharing options...
mojoman Posted November 18, 2012 Author Share Posted November 18, 2012 thanks guys.....door panel says 12/96...and the plug wires I got were for the 05/97-12/97...sometimes the odds don't make a difference....lol...now to get those last 2.5 plugs outta their little holes and new ones in...what a PITA this basic maintenance issue is!!! Link to comment Share on other sites More sharing options...
mojoman Posted November 19, 2012 Author Share Posted November 19, 2012 got the plugs and wires replaced...now it only starts with help(read throttle body cleaner)...where to check fuel pressure???? Link to comment Share on other sites More sharing options...
ivans imports Posted November 20, 2012 Share Posted November 20, 2012 check feul preshure by pinching return hose and see if engine picks up rpms if so pump has a good reserve if not pump is weak Link to comment Share on other sites More sharing options...
porcupine73 Posted November 20, 2012 Share Posted November 20, 2012 got the plugs and wires replaced...now it only starts with help(read throttle body cleaner)...where to check fuel pressure???? Carefully check the intake snorkel hose gadgetry for any hoses that might have popped off. The ones where the IACV intake attaches to the intake tubing, often that hose will pop off and cause the exact issue you describe as much airflow is then allowed to bypass the MAF which confuses the ECU. Link to comment Share on other sites More sharing options...
mojoman Posted November 20, 2012 Author Share Posted November 20, 2012 hooked up my gauge and have 28#'s fuel pressure at idle...thinkin' its on its way out...pricing on a new pump??? thankx guys...appreciate the help!!! Link to comment Share on other sites More sharing options...
