Bounching Tachometer
Today the tachometer on my '86 GL started acting a bit off. Between 2k and 3k RPM it jumps around. Works fine below and above that range. I've checked the ground wires at the coil, and the distributor seems fine. Anything else that would be worth checking? The engine is an EA82T. Thanks in advance.
