Turbone Posted November 25, 2012 Share Posted November 25, 2012 Not sure if this has been discussed or not, but I got this link from a member here (unable to post it) But the info should pertain to all of the US. http://www.gates.com/australia/downloads/download_common.cfm?file=TSB_002_Correct_Timing_Belt_Clearance_is_Critical_On_Subaru_Engines.pdf&folder=news&view=australia&location_id=18884 Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 25, 2012 Share Posted November 25, 2012 I've never seen that happen. But then I always follow the specs on fitment of that guide plate as well as the ones on the DOHC rear belt covers (if equipped). I have never had any trouble at all running a feeler gauge into the gap to check clearance. I always check at the middle and at either end. Same with the corner guides on the belt covers. Neat tool though.... I guess us Americans don't get them? :cool: GD Quote Link to comment Share on other sites More sharing options...
Turbone Posted November 25, 2012 Author Share Posted November 25, 2012 (edited) Havent checked the website yet, but I would assume we do. Went to the corporate site and checked the part numbers, dont see anything listed that was in the TSB yet. Email sent to corporate, will post results. Edited November 25, 2012 by Turbone Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 25, 2012 Share Posted November 25, 2012 I can't find anything about them outside of Australia and the part numbers don't seem to cross over to anything on the US side. GD Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted November 25, 2012 Share Posted November 25, 2012 I know I've seen in the Subaru service info to use a feeler gauge to check the clearance on that guide on the MT vehicles. Maybe some people are just putting it back in without doing that so that it is touching the belt and causing those failures. Because that failure seems like it would happen with a genuine belt or any aftermarket belt. Quote Link to comment Share on other sites More sharing options...
Turbone Posted November 25, 2012 Author Share Posted November 25, 2012 Using a feeler gauge while the engine is still in the car is/would be a pita. When you tighten the bolts it moves the plate tighter, so the tool Gates provides means you dont need to use the feeler gauge, you just stick it in there and tighten the bolts. We really should have this available here :-\ Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 25, 2012 Share Posted November 25, 2012 it seems weird for a manufacturer to issue a TSB about an aftermarket part. and, it does seem you could use 3 narrow loops of solid 18 gauge wire - one in the middle and one at each end - , or, just check with a feeler gauge as mentioned. But, if it came in the gates kit, I'd definitely use it! Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted November 25, 2012 Share Posted November 25, 2012 It's not a Subaru TSB; it's a Gates TSB. That little special tool does look nice. If people really liked them maybe a group buy could get set up to get a couple dozen shipped over from Australia? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 25, 2012 Share Posted November 25, 2012 I remove the radiator 100% of the time when doing timing belts and there is plenty of room to get a feeler gauge in there. GD Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted November 25, 2012 Share Posted November 25, 2012 Agreed, probably esp on the MT's. I've done maybe 5 Subaru TB's, and pulling the radiator is easier than having to try to get all the fan bolts out at least here in the rust belt, and probably even moreso on the MT"s with no AT cooler hoses. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 26, 2012 Share Posted November 26, 2012 Newer stuff the fans remove easier but I like having the extra room and I can blow out the fins of the radiator and inspect it for tank leaks easier with it out. GD Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 26, 2012 Share Posted November 26, 2012 What would be wrong with just removing the guide plate? Quote Link to comment Share on other sites More sharing options...
Turbone Posted November 26, 2012 Author Share Posted November 26, 2012 It's not a Subaru TSB; it's a Gates TSB. That little special tool does look nice. If people really liked them maybe a group buy could get set up to get a couple dozen shipped over from Australia? Correct, I should have pointed that out originally. I remove the radiator 100% of the time when doing timing belts and there is plenty of room to get a feeler gauge in there. GD Yeah, you have plenty of room when the rad is removed. I just think using the FG for setting the guide plate clearance could be problematic. With the tool from Gates its just slap it in there and tighten the bolts. What would be wrong with just removing the guide plate? The guide plate keeps the belt from possibly jumping teeth. Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted November 26, 2012 Share Posted November 26, 2012 I've found that the pull pin for the timing belt tensioner are usually perfect for sliding in there to check them. I have tons of them laying around and seem to work pretty good. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 26, 2012 Share Posted November 26, 2012 The guide plate keeps the belt from possibly jumping teeth. When did jumped timing due to the lack of this guide become an issue? I had heard of some newer cars having problems with that during transport because of the car being rocked around while in gear. It seems to me that EJ engines were sold for about a decade before this little idea came up, how frequently can jumped timing be traced directly back to this guide plate not being in place? Seems to me the timing tensioner should hold adequate tension on the belt to prevent jumping. Quote Link to comment Share on other sites More sharing options...
nipper Posted November 26, 2012 Share Posted November 26, 2012 I remove the radiator 100% of the time when doing timing belts and there is plenty of room to get a feeler gauge in there. GD I didnt know anyone who didnt remove the radiator, just seems like the rational thing to do to give you some elbow room. I do remember, maybe on USMB, one person having a melted TB cover and we just couldnt figure out why it happened, but that was years ago. Quote Link to comment Share on other sites More sharing options...
nipper Posted November 26, 2012 Share Posted November 26, 2012 When did jumped timing due to the lack of this guide become an issue? I had heard of some newer cars having problems with that during transport because of the car being rocked around while in gear. It seems to me that EJ engines were sold for about a decade before this little idea came up, how frequently can jumped timing be traced directly back to this guide plate not being in place? Seems to me the timing tensioner should hold adequate tension on the belt to prevent jumping. Not really. You have to look at it as a complicated system of pullies. You have just the crank moving back and forth just a little bit, not enough to turn the cams. With enough jostling, you can easily get the timing belt to jump. In real daily life, the TB would never ever see this kind of stress so it is not an issue. On a truck being delivered, rolling back and forth not even a complete rotation it can become one. And the more pullies there are, the higher the chances of it happenining. Quote Link to comment Share on other sites More sharing options...
Subaru_dude Posted November 26, 2012 Share Posted November 26, 2012 Not really. You have to look at it as a complicated system of pullies. You have just the crank moving back and forth just a little bit, not enough to turn the cams. With enough jostling, you can easily get the timing belt to jump. In real daily life, the TB would never ever see this kind of stress so it is not an issue. On a truck being delivered, rolling back and forth not even a complete rotation it can become one. And the more pullies there are, the higher the chances of it happenining. So it's there for transport and it can be removed? That's what it sounds like you're saying, but looking at the belt and using my own brain instead of somebody elses judgement I would say that little thing is more or less cheap insurance. I would say removal is a personal call. A good indication it's not necessary is it's not on earlier models. Quote Link to comment Share on other sites More sharing options...
Turbone Posted November 26, 2012 Author Share Posted November 26, 2012 I got a reply back from Gates already. Part number for the tool is 91052. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted November 26, 2012 Share Posted November 26, 2012 Hm couldn't find it with google search, though this page came up, looks like it's basically the PDF but as a web page http://www.gates.com/common/printthis.cfm?BROCHURE=12730&printthis=yes&global=australia Quote Link to comment Share on other sites More sharing options...
Turbone Posted November 26, 2012 Author Share Posted November 26, 2012 I sent another email and got a quick reply. They will be thrown in with the full kits. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted November 26, 2012 Share Posted November 26, 2012 When did jumped timing due to the lack of this guide become an issue? I had heard of some newer cars having problems with that during transport because of the car being rocked around while in gear. It seems to me that EJ engines were sold for about a decade before this little idea came up, how frequently can jumped timing be traced directly back to this guide plate not being in place? Seems to me the timing tensioner should hold adequate tension on the belt to prevent jumping. I'll throw in my two cents on the guide plate. When I did the timing belt on the 06 Legacy I previously owned I noticed the newer style timing belt tensioner doesn't appear to hold the belt and "tight" as the older style tensioners. As a result of that, the guide may be there to help prevent the belt from jumping a tooth. It looks like on the Legacy line, the plate didn't get added until the 3rd gen Legacies, even though the newer style tensioner was used on the 2nd gen Legacies. That tool that Gates came up with is pretty cool! Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted November 26, 2012 Share Posted November 26, 2012 Hm I don't know all applications that use the guide plate, I just assumed it was on all MT soobs. I thought I remember seeing on Endwrench that it was to prevent them from jumping time if parked in gear on a steep hill, I think that's what they said. Quote Link to comment Share on other sites More sharing options...
rxleone Posted November 26, 2012 Share Posted November 26, 2012 I remember when I used to work in a parts store in NZ we had this problem come back from a shop under warranty. The hydraulic tensioner ended up failing, seized and shredded the belt on a late-90's DOHC engine, and the workshop brought the tensioner back to claim the repairs to the engine under warranty. The whole timing assembly was sent away for analysis and it was determined that the engine failed due to the backing plate being set incorrectly, therefore putting the fault on the workshop. Was a nightmare of a position to be in, the middle man between two companies blaming each other, but Gates ended up on top. That's the only time I've heard of it though. Hope it helps. Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted November 27, 2012 Share Posted November 27, 2012 Hm I don't know all applications that use the guide plate, I just assumed it was on all MT soobs. I thought I remember seeing on Endwrench that it was to prevent them from jumping time if parked in gear on a steep hill, I think that's what they said. Pretty much the reason. They started putting the crank guide plate on manual transmission cars as when they were on the boat getting shipped, they were left in gear and would jump the timing belt. Quote Link to comment Share on other sites More sharing options...
