98 OBW 1 & 3 injectors not functioning
98 OBW, 2.5
Ok, been getting misfire codes for a while and decided to take my lunch and play grease monkey.
I started with pulling injector wires. 1/3 pulled had little effect on the engine, 2/4 had negetive reaction. I retested 1 & 3 and I noticed a slight change, mainly when plugging them back in it it was slight.
Ideas?
Edited by MaddCelt
Have you made sure that other things aren't causing the trouble like a bad head gasket or timing belt problem? If you haven't done a compression test yet that might be a good thing to do. To see if the injectors are bad you could swap the sides.
