ivans imports Posted December 21, 2012 Share Posted December 21, 2012 the 2.5 twinn cam interfers in two ways the valves hitt the pistons and they HIT EACH OTHER the intake valve hitts the exhaust valve when out of time. Have built many 2.2 twinn cam engines work very good but had to use the turbo 2.2 headgasket slightly modifyed. I like to use the 2.2 crank in the 2.5 block gives you a 2.35 destroker motor about 8.0-1 then turbo it cheap turbo engine with bulletproof bottom end. Quote Link to comment Share on other sites More sharing options...
xbeerd Posted December 21, 2012 Author Share Posted December 21, 2012 well. today i took the heads off of the ej25d that i had. here's the pics, what do you think? im still a bit novice when it comes to diagnosing things. i see some of the valves are pretty white, would this be due to coolant seepage?? Quote Link to comment Share on other sites More sharing options...
xbeerd Posted December 21, 2012 Author Share Posted December 21, 2012 sorry bout the crappy pictures. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 22, 2012 Share Posted December 22, 2012 (edited) Steam cleaned! That one clean piston is evidence enough, but the others look like they were starting to seep coolant as well. Valves tend to take the same coloring as the spark plugs, a little white means that cylinder is lean. Properly running the valves will be grey but not heavily deposited, and the combustion chamber may have black/brown coloring. Lots of black crud could mean a rich mixture, and/or too many short trips. Basically the black carbon crud will burn off when the engine gets up to operating temp and stays there on a regular basis. A thin layer of carbon will build up on the piston crowns and will stay there unless the engine overheats, or a head gasket goes bad, in which case the carbon gets steamed off. It will start off in small spots, usually closest to the source of the leak. Here's a good comparison. Left side was leaking coolant. You can see a small notch in the bottom left side of the fire ring. Right side is normal. Edited December 22, 2012 by Fairtax4me Quote Link to comment Share on other sites More sharing options...
ivans imports Posted December 22, 2012 Share Posted December 22, 2012 i like to look down the exhaust pipes from heads to see how the burn was a light tan exhaust header port is normal any wet or oil or black or white deposits are i sign of oil or coolant burning. On the short block i rock the #2#4 pistons at tdc to check for slap if slopy the rest is probly slopy to Quote Link to comment Share on other sites More sharing options...
xbeerd Posted December 23, 2012 Author Share Posted December 23, 2012 were you referring to the one clean piston in the pic? i think i took a rag to the thing before taking the picture, it was consistant with the other pistons etc, the spark plugs were a little light on the front cyl's and darker on the rear cyls. in any case, based on those pics, do you think that the head is decently useable? i didnt have any oil on the plugs at all so i think the rings are decent, this car was used for a period of time for the guys wife who dove 5 mins to and from work each day. which would confirm your statement above about the short trips etc. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 23, 2012 Share Posted December 23, 2012 Heads are generally re-usable with little work. Clean them and check for cracks in the combustion chamber. Make sure the valves close all the way. Put it back on. If desired, now is a good time to replace valve stem seals. Quote Link to comment Share on other sites More sharing options...
xbeerd Posted December 23, 2012 Author Share Posted December 23, 2012 Heads are generally re-usable with little work. Clean them and check for cracks in the combustion chamber. Make sure the valves close all the way. Put it back on.If desired, now is a good time to replace valve stem seals. Oh crap. I meant to say 'block' not heads. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 23, 2012 Share Posted December 23, 2012 Block, kind of a toss-up. Biggest problem with the block is the rod bearings are easily damaged by overheating. Supposedly the 99 block is a phase 2 block that has larger rod bearings and should be more resistant to damage. Did you already drain the oil? Check it for shiny flakes. If an engine gets overheated too badly the rear timing covers will deform. They end up with a melty/wavy look near where they bolt to the heads. How do the cylinder walls look? Can you still see the cross hatching? Quote Link to comment Share on other sites More sharing options...
xbeerd Posted December 23, 2012 Author Share Posted December 23, 2012 i thought i recalled seeing some cross hatching, i'll have to double check in some good light. i havent drained the oil yet, so i can check that for goodies. the rear of the tb covers were not warped at all. so... as long as they havent been replaced at some point Quote Link to comment Share on other sites More sharing options...
xbeerd Posted December 27, 2012 Author Share Posted December 27, 2012 verified, yes, i could see there is crosshatching seen on all cylinders:clap: Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 27, 2012 Share Posted December 27, 2012 In that case, flip a coin. Head gaskets are cheap. If you can keep an ear on the engine for funny knocking sounds that get progressively louder, you can slap Sir Frank together and have some fun for a while. It might start knocking right away, might take five or ten thousand miles, maybe it'll run until the car is rusted away. Hard to say. I'd pull the oil pan off while its easy to get to and check real close for metal flakes in the bottom. Some glitter is normal, but if there is an abundance I'd just plan on putting new bearings in it. Another check is to wiggle the rod ends up and down perpendicular to the crankshaft. Any noticable movement is bad news. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted December 27, 2012 Share Posted December 27, 2012 Dude, on schmaus's engine we had rust in 2 of the cylinders, pitting, and rotation resistance with the block that we assembled with after removing the heads. We managed to polish out the rust with PB blaster and the rings doing the cutting. So far the car runs great and does not smoke, for an engine that anyone else may have just thrown away. Yours looks better, ours looks like it sat outside with standing water in the cylinders. Quote Link to comment Share on other sites More sharing options...
xbeerd Posted December 27, 2012 Author Share Posted December 27, 2012 Dude, on schmaus's engine we had rust in 2 of the cylinders, pitting, and rotation resistance with the block that we assembled with after removing the heads. We managed to polish out the rust with PB blaster and the rings doing the cutting. So far the car runs great and does not smoke, for an engine that anyone else may have just thrown away. Yours looks better, ours looks like it sat outside with standing water in the cylinders. holy crap! LOL that makes me feel better about my pile of stuff. Quote Link to comment Share on other sites More sharing options...
xbeerd Posted December 27, 2012 Author Share Posted December 27, 2012 In that case, flip a coin. Head gaskets are cheap. If you can keep an ear on the engine for funny knocking sounds that get progressively louder, you can slap Sir Frank together and have some fun for a while. It might start knocking right away, might take five or ten thousand miles, maybe it'll run until the car is rusted away. Hard to say. I'd pull the oil pan off while its easy to get to and check real close for metal flakes in the bottom. Some glitter is normal, but if there is an abundance I'd just plan on putting new bearings in it. Another check is to wiggle the rod ends up and down perpendicular to the crankshaft. Any noticable movement is bad news. word. i think i'll just slap the frankenmotor together then, sounds like worse case, if i get some knocking and ************ i can just put the 2.2 block back in the middle. the 2.2 is in the car, it starts, smokes a bit, its not blue, but its not necessarly rotten veggie smelling. hard to tell whats what when its 20 degrees outside, 2 of the plugs seemed to have some oil on them that we took out of it. i've taken it around the block a few times, it idles a little rough, but when you put on the gas or let off the gas, it seems to run rough. im gonna try cleaning up some things like the pcv and maf etc and see if that does anything for it. im getting pretty consistant spark on all cyls per my timing gun, i'll try to get a video driving it around so ya can see what im talkin bout. so in the mean time i can checkout and clean up this 2.2 block while the f'nmotor is in why do i do this ************ in winter. LOL Quote Link to comment Share on other sites More sharing options...
xbeerd Posted January 2, 2013 Author Share Posted January 2, 2013 So getting back to the question of interference on this frankenmotor setup. anyone been able to try this out with the clay as mentioned above? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 7, 2013 Share Posted January 7, 2013 (edited) All 2.5 bottom ends when coupled with 2.2 heads are interference. The 96 is MORE interference due to its flat top pistons. It's also a very bad candidate for a FM - the compression is over 12:1 and the ECU will totally freak out. The best FM is made with the '99 25D. Comp. ratio is 10.6:1 and they have 52mm rods. 97/98 are same comp. and 251/253 bottoms will yield about 11.5:1 GD Edited January 7, 2013 by GeneralDisorder Quote Link to comment Share on other sites More sharing options...
96LegacyEJ22 Posted January 7, 2013 Share Posted January 7, 2013 The 96 is MORE interference due to its flat top pistons. It's also a very bad candidate for a FM - the compression is over 12:1 and the ECU will totally freak out. GD Sounds oddly familiar Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 7, 2013 Share Posted January 7, 2013 Yeah it does. It was an experiment. Now it's going to need E85 and a standalone to take advantage of the crazy high compression. GD Quote Link to comment Share on other sites More sharing options...
xbeerd Posted January 7, 2013 Author Share Posted January 7, 2013 thanks for chiming in GD, makes me happy bout my 99 block.. if in fact its the original engine to the car and is a 99. LOL.. i assume it is, is there any visual differences with the 99 block i can look at to make sure its infact a 99 block?? Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 7, 2013 Share Posted January 7, 2013 (edited) Check the VIN etching on the bell housing. Tenth digit should be a X for 1999. This would tell you the model year of the vehicle the engine came from, if it is not original to the car. Edited January 8, 2013 by Fairtax4me Fixed incorrect letter/year designation Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 7, 2013 Share Posted January 7, 2013 99 block will be an 8 bolt bell-housing. It's the only 8 bolt dual cam N/A out there.... Well till you get into the H6's and newer FB/FA engines, etc. It's really a 251 case/crank/rods with 25D pistons. A little trick on Subaru's part. GD Quote Link to comment Share on other sites More sharing options...
xbeerd Posted January 7, 2013 Author Share Posted January 7, 2013 (edited) i couldnt find the vin at first on the block, had to get out the degreaser and a brush i found it, its a X, which per the decoder shows its a 99 motor, (plus the vin matches) Thanks guys, im absorbing all these little notes about the differences. hey what are these markings on the block (mine are different but this was the only pic i could find showing them, i couldnt find any answer on the web or here the 73 3 followed by a symbol. is that a piston designation? Edited January 7, 2013 by xbeerd Quote Link to comment Share on other sites More sharing options...
czny Posted January 7, 2013 Share Posted January 7, 2013 (edited) Check the VIN etching on the bell housing. Tenth digit should be a W for 1999. This would tell you the model year of the vehicle the engine came from, if it is not original to the car. Sorry for this highjack but maybe this could be useful for others.... I have a 99 Lego OB EJ25 short block here with an "X" as the tenth digit. It was a DOHC & is 8 bolt bell-housing pattern. Don't know the mileage as the donor odometer was missing when I pulled it. Guess I'll find out the rod journal size when torn down for brgs/rings. Were there any other variations to this tenth digit "W" designation? Edit: xbeerd posted his "X" just as this post was being typed.:cool: Edited January 7, 2013 by czny Quote Link to comment Share on other sites More sharing options...
xbeerd Posted January 7, 2013 Author Share Posted January 7, 2013 Sorry for this highjack but maybe this could be useful for others.... I have a 99 Lego OB EJ25 short block here with an "X" as the tenth digit. It was a DOHC & is 8 bolt bell-housing pattern. Don't know the mileage as the donor odometer was missing when I pulled it. Guess I'll find out the rod journal size when torn down for brgs/rings. Were there any other variations to this tenth digit "W" designation? i think he just goofed, W shows 1998. X for '99 per this site.. http://www.cars101.com/subaru/vin.html Quote Link to comment Share on other sites More sharing options...
