hellosubaru Posted November 30, 2012 Share Posted November 30, 2012 (edited) If the dates don't make sense in this post, it's because I copied this build thread from another local Subaru forum I run. I figured people on USMB would like to see this too. So, I've never really done a build thread before, so I figured, hey, why not? Before the build/rebuild part starts, here's a little history on the car: I purchased this '86 GL for $150. Both front hubs were stripped, so I had a RWD soob for a while. The one tire fires in the rear were awesome. It came with the stock 1.8 carbed EA and the DR 5spd. Fast forward a few months. Both hubs are replaced, and it runs pretty decent. . After the lift went in, it needed a little more gusto. My friend Andy found a guy getting rid of a whole '93 Legacy for $150. He had punched a hole in the torque converter, and was done with the car. So out with the EA: The same day I picked up the EJ, I found a guy in the Seattle area (I think Suberdave?) getting rid of a whole EJ turbo swap (turbo, heads, DP, lines, etc.). After all said in done, in with the turbo EJ: At the same time, it got a fresh coat of bedliner: So here's how it stood: This concludes our history lesson. Now for the rebuild and upgrades. Edited November 30, 2012 by hellosubaru Link to comment Share on other sites More sharing options...
hellosubaru Posted November 30, 2012 Author Share Posted November 30, 2012 09/04/2012, Andy and I got the EJ22E-T pulled from the GL: Yesterday, Andy measured tolerances and put the pistons in the freshly machined block (thanks to Adam at NWRS): More next week. Link to comment Share on other sites More sharing options...
hellosubaru Posted November 30, 2012 Author Share Posted November 30, 2012 09/11/2012 we got the long block mostly assembled: And a few pictures of some of the parts I've been collecting for this build over the past year: Next time we should finish the long block, and start working on all of the EJ drivetrain parts. 09/18/2012, Engine is now fully built: Link to comment Share on other sites More sharing options...
hellosubaru Posted November 30, 2012 Author Share Posted November 30, 2012 Well, not much happened this week (10/02/2012), I got the EA diff out, and compared it with the EJ diff. They are pretty much identical on the outside. It's amazing that these were manufactured 14 years apart from each other: I just need to figure out how to get the EA axles splined to the EJ diff. I think I'm either going to swap the carrier from the EA (since it's an LSD) to the EJ, so I can bolt the stub shafts in and use the EA axles, or use EJ inner cups with the EA axles, I'm not sure yet. So if you have an opinion, let me know! EA: EJ: Here's the EJ trans mocked up in the EA: Hopefully there will be much more progress next week! Link to comment Share on other sites More sharing options...
hellosubaru Posted November 30, 2012 Author Share Posted November 30, 2012 The last three weeks (10/02 - 10/16/2012), we've been working on the trans mount/guard for the EJ trans. It's now complete, thanks to my friend Alex: Next up is re-gearing the trans, swapping around diff parts (carriers and gearing), and figuring out the driveshaft and linkage. Not much has happened in the past few weeks (10/23 - 10/30/2012). I've done a lot of wiring, and we started on the rear disk swap last night. -Jason Link to comment Share on other sites More sharing options...
hellosubaru Posted November 30, 2012 Author Share Posted November 30, 2012 11/04/2012, my bros and I finished up the rear disk swap and 6 lug conversion: 11/06/2012, my friend Andy tore down and rebuilt the 5spd trans with 4.44 gears. Old gears: New: Also, my other friend Marcus, and I, did a bunch of wiring for the control panel and in cabin winch controls, along with new power distribution. Link to comment Share on other sites More sharing options...
hellosubaru Posted November 30, 2012 Author Share Posted November 30, 2012 Well, it's been a few weeks. Work has been extremely busy, and the Thanksgiving weekend was thrown into the mix, but progress has been made. The transmission is rebuilt, and installed in the car: The rear end has also been re-geared: 3.70 LSD is now a 4.44 LSD The LSD swap was quite simple. I had a 4.44 open diff out of an Outback. We just took the ring and pinion out of the Outback diff, and swapped it into the GL diff with the LSD. Also, the switch control panel was finished: The shift linkage has also been shortened, and the driveshaft is at Driveline Services getting shortened as well. The last thing on the agenda is the turbo swap, and beefy battery cables. After that, it's just buttoning up all the loose ends! Link to comment Share on other sites More sharing options...
El Presidente Posted November 30, 2012 Share Posted November 30, 2012 Very Nice!! I like the bracket you made to put the EJ tranny in there. What did the tranny start as gearing wise, and where did you get your 4.44 gearset? I have a question about your bedliner...That looks like herculiner right? How much did you put on? How many layers? Happy with it? I'm still in the fabrication phase, but after all my exterior stuff is done, I'm planning on putting 2-3 gallons of OD green on the outside and probably 2 gallons on the inside of dark grey. How did you go about masking the windows and other areas you don't want covered? Did you remask your edges after every coat or did you just mask once and carefully remove it when you were done? Josh Link to comment Share on other sites More sharing options...
El Presidente Posted November 30, 2012 Share Posted November 30, 2012 What other forum are you on/run? Link to comment Share on other sites More sharing options...
hellosubaru Posted November 30, 2012 Author Share Posted November 30, 2012 El Presidente said: What other forum are you on/run? https://www.farnorthflatfour.com. It's fairly new, not many members. Link to comment Share on other sites More sharing options...
hellosubaru Posted November 30, 2012 Author Share Posted November 30, 2012 (edited) El Presidente said: Very Nice!! I like the bracket you made to put the EJ tranny in there. What did the tranny start as gearing wise, and where did you get your 4.44 gearset? I have a question about your bedliner...That looks like herculiner right? How much did you put on? How many layers? Happy with it? I'm still in the fabrication phase, but after all my exterior stuff is done, I'm planning on putting 2-3 gallons of OD green on the outside and probably 2 gallons on the inside of dark grey. How did you go about masking the windows and other areas you don't want covered? Did you remask your edges after every coat or did you just mask once and carefully remove it when you were done? Josh The transmission started off as a 4.11. I purchased the 4.44 gear set from subarugenuineparts.com, the ring and pinion was a direct swap. I have the part number somewhere if you're interested. As for the bedliner, it's worked ok. I don't think I prepped as well as I should have. I did 2 coats, but a lot of it has worn off in one year already. Again, I attribute this to bad prep on my part. I used 2 gallons for the exterior. As for masking, I just masked once, and it turned out pretty good. Edited November 30, 2012 by hellosubaru Link to comment Share on other sites More sharing options...
torxxx Posted November 30, 2012 Share Posted November 30, 2012 what year make model did you use to find 4.44 R&P? It'd be nice to swap that into my 5mt Link to comment Share on other sites More sharing options...
Numbchux Posted November 30, 2012 Share Posted November 30, 2012 torxxx said: what year make model did you use to find 4.44 R&P? It'd be nice to swap that into my 5mt I posted a part number in one of my threads....can't find it now. But the application I used was a 2004 Forester XT. But it's the same part for many models, and the part number for the older jdm 4.444 5MTs has been superseded for the FXT part #. Link to comment Share on other sites More sharing options...
hellosubaru Posted November 30, 2012 Author Share Posted November 30, 2012 Numbchux said: I posted a part number in one of my threads....can't find it now. But the application I used was a 2004 Forester XT. But it's the same part for many models, and the part number for the older jdm 4.444 5MTs has been superseded for the FXT part #. The part number I have on file that I used is 38100AB680. Link to comment Share on other sites More sharing options...
torxxx Posted December 1, 2012 Share Posted December 1, 2012 sweet thanks.. insta-googled it for ************s and giggles. 314 bucks on a random subaru parts website. Price sound about right? They didnt have a picture of the part, just Gear set HYP was the only info the part number had Link to comment Share on other sites More sharing options...
hellosubaru Posted December 1, 2012 Author Share Posted December 1, 2012 torxxx said: sweet thanks.. insta-googled it for ************s and giggles. 314 bucks on a random subaru parts website. Price sound about right? They didnt have a picture of the part, just Gear set HYP was the only info the part number had SubaruGenuineParts has it for $287 if I remember right, and they are legit. Link to comment Share on other sites More sharing options...
Numbchux Posted December 1, 2012 Share Posted December 1, 2012 I got it from 1st Subaru (Now http://www.discountedsubaruparts.com ). I just pulled up the invoice email, it was the same part number posted here, and was $311 after shipping ($283 before). Link to comment Share on other sites More sharing options...
hellosubaru Posted March 8, 2013 Author Share Posted March 8, 2013 Finally, an update! In late December, I finished up with installing the new engine/trans/everything else. I took it for a few test runs, and everything was running great. After a few days, I started wrestling with drive-ability issues (erratic idle, misfires, no power, etc). I couldn't tell if the ECU was still relearning, or if there was an issue with one or more of the sensors. It kept going down hill, until it wouldn't start anymore. I finally found out it wasn't running correctly due to it constantly fouling spark plugs. I did a fuel pressure test on the feed side, and had 66psi of fuel pressure. Ouch! I tested the return side, and there was almost 80psi, so it looked like I'd be replacing my return fuel line. I think it was a combo of being a very small (1/8") return, blocked, and possible a pinched hard line. After replacing the fuel lines, the car ran great, and has continued to for about 2-3 weeks now! Here are some pics of the finished product: Next on the list of things to do: hood scoop for IC, lighter front bumper, fix exhaust, and give it a little more lift. Link to comment Share on other sites More sharing options...
Steve W. Posted April 12, 2013 Share Posted April 12, 2013 Lookin' good man. Did you rework the wiring looms your self? I've got my engine hanging in the stand ready to go, it's a 2.2T, goin' into my 88 GL10T wagon. The wiring's my next hurdle, and I don't know whether to tackle it my self or buy one from someone else. Whata' you think, I'm so close now, I'm really anxious? Nice thread, hang in there. Steve. Link to comment Share on other sites More sharing options...
sikend667 Posted April 26, 2013 Share Posted April 26, 2013 On 11/30/2012 at 1:36 AM, hellosubaru said: https://www.farnorthflatfour.com. It's fairly new, not many members. not from bellingham so not sure that im welcome but do like the layout/concept of this forum! Link to comment Share on other sites More sharing options...
kamnk Posted April 27, 2013 Share Posted April 27, 2013 On 11/30/2012 at 12:10 AM, hellosubaru said: 09/04/2012, Andy and I got the EJ22E-T pulled from the GL: Yesterday, Andy measured tolerances and put the pistons in the freshly machined block (thanks to Adam at NWRS): More next week. is this ej22t closed deck block Link to comment Share on other sites More sharing options...
Uberoo Posted April 27, 2013 Share Posted April 27, 2013 totally digging the pink transmission crossmember! I think I'm going to go and replace my return line with 5/16.My EJ might run better,and my POS ford fuel pump might be a bit quieter. Link to comment Share on other sites More sharing options...
