Mugs Posted December 25, 2012 Share Posted December 25, 2012 Where did all you pics go. Its-a-sayin you deleted them??????? I want to have a looky see. Quote Link to comment Share on other sites More sharing options...
lostinthe202 Posted December 26, 2012 Share Posted December 26, 2012 Where did all you pics go. Its-a-sayin you deleted them??????? I want to have a looky see. Ditto! Quote Link to comment Share on other sites More sharing options...
monstaru Posted December 26, 2012 Author Share Posted December 26, 2012 WElp replced the picture up front, and here are some more. Just put the tires in front of her to see Finally got my wheels welded up Test fitting the bellhousing.I need to get anotherr Subaru hydro clutch.The one I have is from some other model i guess.Because it does nto match this bolt pattern. Wheels all painted up, I thought I would like the whiite background.But don't.Ima change it to drab.... whipped up a twin stick setup... Still working on the fluid barrier, I sat around the other night with sandpaper(300 grit-ish, and 1000 grit) and polished the inside leading edges of the twin sticks to get them to move more fluidly next to each other.Then hit them with a dremel and some rouge.. The whole layout, teting bolt sizes, looking azt length etc.... Thats about it, I think I have made a deal on My Subie EJ d/r, so I will have the scrilla to throw at this thing again soon. I need ARP studs for my knuckles, then I can put stuff together the way I want to!! cheers 1 Quote Link to comment Share on other sites More sharing options...
obk25xt Posted December 27, 2012 Share Posted December 27, 2012 I like that you build your stuff.... I have said that before somewhere, I just wanted to reiterate the point...... Quote Link to comment Share on other sites More sharing options...
Subruise Posted December 27, 2012 Share Posted December 27, 2012 I agree with this statement. Inspiring. really?? he just makes me kinda wanna give up lol Quote Link to comment Share on other sites More sharing options...
mellow65 Posted December 28, 2012 Share Posted December 28, 2012 the clutch slave has to be from like a 2.5rs style. NA hydraulic, same with the clutch fork. 1 Quote Link to comment Share on other sites More sharing options...
monstaru Posted December 28, 2012 Author Share Posted December 28, 2012 (edited) the clutch slave has to be from like a 2.5rs style. NA hydraulic, same with the clutch fork. I looked just slightly earlier than you posted.It is literally from 2.5 5 speeds. from like 97 to whenever that generation ends. Got athe proper Slave, and mounted it up the trans to make sure it fit. Then checked the fitting to the Toyota master cylinder.. Cheers:drunk: Edited December 28, 2012 by monstaru Quote Link to comment Share on other sites More sharing options...
monstaru Posted December 29, 2012 Author Share Posted December 29, 2012 All mounted up . She is sitting on her own Two feet again in the back cheers 1 Quote Link to comment Share on other sites More sharing options...
monstaru Posted December 30, 2012 Author Share Posted December 30, 2012 (edited) I got the t case lined up,the4n realized the crosmember I got for my 85 frame, didna line up with an 82?ish frame.... So , gotta remedy that.... And then remedy the front shock towers.The preliminary numbers state tthat the ford Towers are not going to work in this sitcheachin. So , gotta deal with that... Then we shall see what comes a knockin... \cheeres Edited December 30, 2012 by monstaru Quote Link to comment Share on other sites More sharing options...
monstaru Posted December 31, 2012 Author Share Posted December 31, 2012 DOH....evidently there is one set of crossmembers from 79-82, and 83-85.Nice. Well,I guess I will be needing to build a crossmember..DOH! cheers Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted December 31, 2012 Share Posted December 31, 2012 I have one from a 80 or 81 if that helps Quote Link to comment Share on other sites More sharing options...
monstaru Posted January 1, 2013 Author Share Posted January 1, 2013 I have one from a 80 or 81 if that helps It would help if you were down the road.But you're not I am gonna pick up a DIY t-case plate from a new buddy down here.Should be able to make something happen from that. cheers Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted January 1, 2013 Share Posted January 1, 2013 My buddy & I cut his cross member in pieces to build a custom mount for his Chevy motor & trans. We used the sides, but welded in a plate for a new bottom. Im sure you could do it in an hour... cut each end off... bolt them to the frame. Tack replacement plate in place... remove and finish. Quote Link to comment Share on other sites More sharing options...
monstaru Posted January 2, 2013 Author Share Posted January 2, 2013 My buddy & I cut his cross member in pieces to build a custom mount for his Chevy motor & trans. We used the sides, but welded in a plate for a new bottom. Im sure you could do it in an hour... cut each end off... bolt them to the frame. Tack replacement plate in place... remove and finish. I have a buddy down the road with a CNC plasma table.He is going to be cutting me a mount like the Front Range Offroad DIY mount.I will be using that once I get it this week. I should have the rest of my axle rebuild stuff by Friday,including my hub gears. Then I will be putting that stuff together. I am looking at trading the tires I have due to them being radials..... But with my twin stick almost done,I have alot of irons in the fire right now. Cheers Quote Link to comment Share on other sites More sharing options...
jbbvw Posted January 3, 2013 Share Posted January 3, 2013 I finally found your thread. Freaking bad*ss man! I'm gonna have to come see it in person soon. And you gotta come see my s**t sometime soon too. Jesse Quote Link to comment Share on other sites More sharing options...
monstaru Posted January 3, 2013 Author Share Posted January 3, 2013 (edited) I finally found your thread. Freaking bad*ss man! I'm gonna have to come see it in person soon. And you gotta come see my s**t sometime soon too. Jesse Totally man!I'm kinda busy at work right now,but let's shoot for beers next week. Cheers Edited January 4, 2013 by monstaru Quote Link to comment Share on other sites More sharing options...
ezapar Posted January 4, 2013 Share Posted January 4, 2013 I finally found your thread. Freaking bad*ss man! I'm gonna have to come see it in person soon. And you gotta come see my s**t sometime soon too. Exactly what he just said. Quote Link to comment Share on other sites More sharing options...
rpholz Posted January 4, 2013 Share Posted January 4, 2013 Ill be watching this thread, very excited to see how it turns out. Keep up the good work! Quote Link to comment Share on other sites More sharing options...
monstaru Posted January 5, 2013 Author Share Posted January 5, 2013 (edited) Brown Santa showed up.My front axle stuffs I also thank Wentz for some steering arms. giggity:-p cheers Edited January 5, 2013 by monstaru Quote Link to comment Share on other sites More sharing options...
monstaru Posted January 6, 2013 Author Share Posted January 6, 2013 Exactly what he just said. Come on down!Both of ya's!! I want to put together a "Bed Patrol" shake down run lol cheers Quote Link to comment Share on other sites More sharing options...
monstaru Posted January 8, 2013 Author Share Posted January 8, 2013 (edited) Ok.. umm, Alright, so just picked up my hub gears. Gonna hi"T" it hard this weekend. cheers Edited January 8, 2013 by monstaru Quote Link to comment Share on other sites More sharing options...
Subruise Posted January 8, 2013 Share Posted January 8, 2013 i try to *hi* it hard every weekend:grin: Quote Link to comment Share on other sites More sharing options...
monstaru Posted January 8, 2013 Author Share Posted January 8, 2013 Come on Down!:cool: i try to *hi* it hard every weekend:grin: Quote Link to comment Share on other sites More sharing options...
ezapar Posted January 9, 2013 Share Posted January 9, 2013 Did you build those decals? Yeah, we should make up a Saturday afternoon/evening to hang out and see your stuff. Quote Link to comment Share on other sites More sharing options...
monstaru Posted January 14, 2013 Author Share Posted January 14, 2013 So, I needed to add accoutrement for shock mounting in the front. Then needed to start the shockmounts Then I started the other side, and forgot to seat the pin on the follower:,,,, Decided to move onto the axle again. Fingeredd on this being the last mods to the axle before being put together. cheers Quote Link to comment Share on other sites More sharing options...
