Smiley..........
monstaru
Ok, So it is progress, albeit codswalloping nerve racking at that.
Please note that the tubing holding things together is not necessarily placed whee it will stay...
No turning back now!!!
Gotta see where she is gonna sit.ish....
Fish plating partially welded.One side almost done.
T-casew ia almost lined up in it's stock position.
But just a couple inches higher.
Defenitely not super proud of my upside down welds, but you try it ! :) lol
Gotta make those damn elusive motor mounts next.
overall view
I think thats all I have for now.
cheers
  • Like 2
Very cool, I've never seen a patch of frame replaced with tube like that....but I've seen the whole front clip made of tube....so I don't see why it won't work. Pretty cool idea to make a little extra clearance! And it looks like it's given you quite a bit of room where you needed it.
Excellent work
  • 2 weeks later...
Excellent work
It is already changing ....
As I sit here and look at the horrible body mounts,
and uneven hacking of the frame mounts ,
the disfigured, not all the way welded,defunct
steering box mount...
and ugly azz bumper...
I am thinking tube .Lots  , and lots Of tube.
Still maintaining fenders, and a hood . Maybe even try to squeeze a grill back in there...
ha d a friend cut some stuff out on his Plasma table. He welded up a base hanger for me, and I added a 2x2x1/4" mounting surface for some Tube.
Then bought some 1.75" DOM.
When I get back at her, It's gonna be epic.
cheers
Edited by monstaru
Yeah, shotty  building sux!!
body mount
cut out for the  steering box...
This codswallopin' monstrosity looks WAY better on the floor. LOL
Way more room to work now.
Looking at it with a fender
cheers
I smiled a lil when I seen that pile of front frame on the floor haha.... Funny how much bigger the iceberg is below the suface.......
Keep up the good work, it will payoff in the end.....
I had a friend tell me once to build what I want. Best advice I ever got.
I really like driving. But I enjoy fabrication more sometimes.
DOwn the rabbit hole is where I belong :)
I have been contemplating going to RUF .
I have the Waggy springs up there now.
I think that I will try to pick up some 3rd gen rears.
Push the front forward a bit.
Nice and open up there now :)
cheers
Edited by monstaru
  • 2 weeks later...
I also am ready to build (have materials now)a skid plate mount/t-case mount. I can get ready to fully test suspension here real soon. I have had several moments of doubt during this entire situation.
However times are looking up, and I am enjoying the time I get to spend on it.
I think I can get the front straightened out pretty quick here, now that the base measurements have worked out. I was slightly retarded because I forgot to put the plumb bobs down before I cut the front of the frame off.DOH!!!
Looks cool.  Keep it going, I want to see what happens.  It looks like it's going to be super custom, the kind where guys squint to see it far off 'cause they can tell it's built.  Looks like your making an awesome approach angle, but I still can't quite tell exactly where you're going with it.
I am going EVERYWHERE with it!!!!
B)  LOL
I got pretty far today.
First , I set her on her own weight.
Then I put the knuckles on the axle, wheel bearings , etc. So I could hang some tires.
Now that's an approach angle:)
Overall, pretty solid
cheers
  • Like 1
Just taking a look.
Figured that I would start cycling the front suspensio, and realized I wasna done with my rear Diff.Gotta get the rear on tires again before I am comfortable stretching her out.
Sourced my bearings for the spool swap.
Got the back lash set then started trying to make a pattern.Well.damnit.I can be retarded sometimes.TO much paint.
DOH!!!
I will go home today and clean it up, then run it and figure it out. LOL
cheers
Edited by monstaru
