subarurx yo Posted December 8, 2012 Share Posted December 8, 2012 my tranny just got destroyed today and i got a ftawd d/r tranny i wanna put back in my rx, but when i drained the oil was very grey and sparkly, with a bit of shavings on the magnetic plug and a lot of input shaft play and leaky seals, so the question is where would i get parts such as bearings and what not if all the parts seem good? and is there anything special about doing this task? Link to comment Share on other sites More sharing options...
subarurx yo Posted December 10, 2012 Author Share Posted December 10, 2012 anyone? Link to comment Share on other sites More sharing options...
AKghandi Posted December 10, 2012 Share Posted December 10, 2012 usually when you post something and no one responds it means they want you to search it. the search function is kinda weird so what do is use google and put ultimate subaru after it like "transmission bearing replacement, ultimate subaru" if i knew anything about the inner workings of the transmission i would help but im just as in the dark as you. Link to comment Share on other sites More sharing options...
idosubaru Posted December 10, 2012 Share Posted December 10, 2012 Subaru will have those parts. search for "input shaft bearing" Gloyale is a user here who has a nice write up on a transmission tear down...I forget what he was replacing but I think it was an input shaft bearing? Subaru transmissions are largely similar since the later 1980's to now so expect similar overall process. you can't use 3 letter terms in the search here. but you can search via username and select "thread started by" to see what threads they started. enter Gloyale into that box and click "started by" and a search string..."input shaft bearing" or something and see if you can find his trhead. google is a good option, do the search you want and then google will provide a link under one of our search hits that says something like "more results from ultimate subaru...." click that link. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 10, 2012 Share Posted December 10, 2012 (edited) It's a very expensive proposition typically. I rebuild transmissions quite a bit and parts costs can often kill the viability of it. Used transmissions are almost always cheaper. Most of the parts have to be ordered through Subaru as they are not generic. The prices will astound you I'm sure. The last EJ 5MT I did a full bearing/synchro job on was something like $800 in parts. For a turbo race transmission with a front LSD this isn't an issue. For an EA dual range its way out of the price range of viability. You'll need a press, bearing splitters, and pullers/drivers, etc at a minimum to do a rebuild on a transmission. GD Edited December 10, 2012 by GeneralDisorder Link to comment Share on other sites More sharing options...
subarurx yo Posted December 10, 2012 Author Share Posted December 10, 2012 alright i just miss awd because fwd is just killing the tires i got access to a press at school and i suppose i will disassemble and look at it. Link to comment Share on other sites More sharing options...
coxy Posted December 20, 2012 Share Posted December 20, 2012 GD a good trick I and others I know in the rally preparation business use with the Brass Cone Borg warner style syncros is to tape up the sections on the gear you dont want blasted and glass bead the syncro cones and the matching section on the gear. Often when the syncro is lazy rather than damaged on the little gear teeth glass beading to give a satin type finish will bring the syncro action back to as new for years of road use. Even in the rally cars they are generally good for a couple of seasons with a good driver,Bad drivers on the other hand can destroy a gearbox in one event. Link to comment Share on other sites More sharing options...
Gloyale Posted December 21, 2012 Share Posted December 21, 2012 I ussually just do the 4 main bearings. 5 with a D/R, and all the seals. unless there is obvious damage to anything else. runs about $350 from the dealership. Link to comment Share on other sites More sharing options...
ivans imports Posted December 21, 2012 Share Posted December 21, 2012 i have 25 tranys apart if you need a specific part only two awd units for rx and one from xt 6 Link to comment Share on other sites More sharing options...
ivans imports Posted December 21, 2012 Share Posted December 21, 2012 I have a press setup just for subaru tranys and it gets used alot the trick is to find a very low profile berring spilter had to get a snapon one and grind it down to get it to fitt under the berrings and gears. On average it takes about 1-1/2 tons force to press the shafts apart Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 23, 2012 Share Posted December 23, 2012 I ussually just do the 4 main bearings. 5 with a D/R, and all the seals. unless there is obvious damage to anything else. runs about $350 from the dealership. It's a slippery slope though if you haven't got first hand experience with the transmission. If you have driven it and know the syncro's to be good then I can see going that route but if you are rebuilding one that's unknown I tend to just replace them all. And even at $350 - you can usually find a good used one for half that. Interesting option with the bead blasting. Though when I've seen bad syncro's they often have all the ridges worn flat and I'm not sure those could be saved. With respect to "bad" syncro's - try the Subaru Extra-S gear oil first. I've had that clean up a lot of transmissions with a grind here or there. It's well worth the entry price. I stock it at my shop so anyone in my area can get a gallon of it for less than the online sources that sell it in liters. GD Link to comment Share on other sites More sharing options...
subarurx yo Posted December 26, 2012 Author Share Posted December 26, 2012 i have 25 tranys apart if you need a specific part only two awd units for rx and one from xt 6 do you have the dr quill shaft/ball bearing holder, mine broke on the press due to me not looking for all the snap rings and getting in a rush. anyways ive looked at everything and cleaned parts up in a solvent tank and all the syncros "appear" fine just 2-3 one is a little jammy Link to comment Share on other sites More sharing options...
idosubaru Posted December 26, 2012 Share Posted December 26, 2012 With respect to "bad" syncro's - try the Subaru Extra-S gear oil first. I've had that clean up a lot of transmissions with a grind here or there. how about popping out of gear, would it help that? too late for my friend who had this issue laste year but good to know. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 26, 2012 Share Posted December 26, 2012 Do you know what a good synchro is supposed to look like? How do you define its appearance as being "good"? What characteristics comprise a good appearance vs. a bad one? Have you removed them from the shaft? You can't inspect the syncros without complete shaft disassembly. I've had luck with Extra-S in conjunction with shifter bushings solving some instances where the transmission pops out of gear. Most recently I solved a 2nd gear popping problem on an '06 WRX. GD Link to comment Share on other sites More sharing options...
subarurx yo Posted December 26, 2012 Author Share Posted December 26, 2012 well i suppose i made a bad call i just knew that it shifted fine except into 3rd i couldn't shift very fast because it wouldn't go, just kinda jam. I just kinda spun the parts on the shafts and would try sliding the collar on the 3rd gear one and i would have to wiggle things to get it to slide on. The little teeth on all of them have the same shape to them with the triangular ends on one side. All the other gears i just free spun them and quickly slid the collar and they would engage just 2-3 is a little weird. This is the first time doing anything to a tranny, so im trying to learn Link to comment Share on other sites More sharing options...
subarurx yo Posted December 26, 2012 Author Share Posted December 26, 2012 im also not to worried about the 3rd gear problem either as i don't speed shift anymore as I assume it's harder on things with a bit more torque than stock(I snapped a ball joint, ruined rear end, and went through my clutch pretty fast, probably from clutch dumping. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 27, 2012 Share Posted December 27, 2012 The teeth on the outside of the synchro are never worn since those aren't what do the work - those are just the drive teeth or "shift dogs". The "teeth" that need to be inspected are on the inside diameter of the synchro and cannot be seen or inspected without removing them from the shaft. These are a very tiny (1/32"-1/16") series of SHARP ridges that run around the inside diameter and have a cross-section like a saw blade. They engage with the matching cone of the freewheeling gear and pull it up to speed durring the shift. These are what cause grinding and poor shifting behavior when worn because if they are not sharp and defined they will not grab the gear and spin it up to speed before the shift collar engages the dogs - causing them to grind into each other rather than smoothly engage. You can tell absolutely nothing without shaft disassembly but the forces required to disassemble many of the components will apply force through the rolling elements of bearings - generally requiring their replacement as that is not acceptable bearing protocol. GD Link to comment Share on other sites More sharing options...
subarurx yo Posted December 27, 2012 Author Share Posted December 27, 2012 thanks for the info I researched syncros briefly but not much understanding untill i had a tranny apart. I will probably just get the few parts i need and put her together Link to comment Share on other sites More sharing options...
