cohophysh Posted December 14, 2012 Share Posted December 14, 2012 got a 90 leg wagon that has been sitting and it looks like mold is starting to set in, seems to be alot of moisture inside, windshield leaks some, ...any suggestions to reduce the moisture/mold? Link to comment Share on other sites More sharing options...
cal_look_zero Posted December 14, 2012 Share Posted December 14, 2012 Well your best bet is to open it all up on a warmish day and let it burn off. You could also put a couple tubs of "damp rid" in to soak up any humid moisture. Otherwise, pull the interior and carpet and use a good extractor on them to pull all the moisture out. Link to comment Share on other sites More sharing options...
ajp Posted December 14, 2012 Share Posted December 14, 2012 Im having a similar problem. a friend said that she used an ionizer on an old motor home and it killed it all in 24 hours. so I am going to try it. had my 84 parked at a farm and the chickens pecked off the little gasket to the rear windshield wiper. took me days to figure out how it was leaking. parked it on a hill in a 5 day torrential downpour, and water had run all the way to passenger side floor, about 2 inches deep. try drying that out in Oregon. car just reeks of mildew so bad I am ready for a divorce. Link to comment Share on other sites More sharing options...
idosubaru Posted December 14, 2012 Share Posted December 14, 2012 get an Ozone generator. places that rent tools, lifts, and such have them. You can also rent them online. Get one, plug it in and let it run in your car all night long. Have the floor matts out so they aren't covering the carpet, glove box and center console open, windows shut. I pull everything out of the car that i can easily and then also try to run the car for an hour or so with the vents on so it's cycling through all the HVAC. stuff works amazing. Link to comment Share on other sites More sharing options...
