Ricearu Posted December 17, 2012 Share Posted December 17, 2012 I need the specs (length and count) on the engine case bolts for a 2.5 phase 2. I got all the bolts thrown in a box, and don't know what is what. Please help. Quote Link to comment Share on other sites More sharing options...
cal_look_zero Posted December 17, 2012 Share Posted December 17, 2012 There's eight 12 point head long length bolts, two 12 point head medium length bolts, seven 6 point (12mm head) short bolts, and one little turd 10mm head bolt that goes under the oil pan. Sorry I don't have measurements, hopefully that helps a bit. Quote Link to comment Share on other sites More sharing options...
Ricearu Posted December 18, 2012 Author Share Posted December 18, 2012 I have a box of huge bolts from several engines, a helper of mine threw all the bolts from several engines in a box. I don't want to use the wrong bolts. Quote Link to comment Share on other sites More sharing options...
ivans imports Posted December 18, 2012 Share Posted December 18, 2012 all the same exept 4 the two with non gasketed washers go at the back of block no water jacketed the two short ones go in front of block no gasketed washers there is one long smaler bolt gos on front the rest are perty strait forward i glue the washers on all the bolts with washers Quote Link to comment Share on other sites More sharing options...
