el_freddo Posted December 26, 2012 Share Posted December 26, 2012 G'day - this could be a stupid question from a crazy Aussie, but here goes anyway: If I was going to drop a 4.10:1 ratio rear diff into my subi with a 4.111:1 front ratio what would be the consequences of this on the viscous centre diff? Got an idea in my head that I want to do on the cheap if possible - I really don't want to buy a new R&P set if possible, but I also really don't want to destroy my centre diff. I know the ratios are close, but are they close enough not to do damage? Cheers Bennie Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted December 26, 2012 Share Posted December 26, 2012 I have no experience but, when these type issues come up, I often wonder if there's a way to compensate with different tire sizes on front vs rear axle. maybe not practical for many people but, just a mental exercise hah! Link to comment Share on other sites More sharing options...
Gloyale Posted December 26, 2012 Share Posted December 26, 2012 Not sure about damaging anything. With that setup you'd have a slight rear power bias......might be good for drifting:brow: Perhaps run some slightly worn down tires on the back, and brand new up front? Link to comment Share on other sites More sharing options...
presslab Posted December 26, 2012 Share Posted December 26, 2012 Subaru once specified a maximum difference of 1/4" in tire rolling circumference. Although they also supplied a doughnut spare that violates that. Anyway the difference of 4.1 and 4.111 is 0.27%. 1/4" on a 205/50-15 tire for example is 0.35%. I think you will be just fine, just be sure to rotate the tires as scheduled. Link to comment Share on other sites More sharing options...
el_freddo Posted December 28, 2012 Author Share Posted December 28, 2012 Ok, I'm not keen on running the different ratios, even if it is a tiny bit out. Through some other questions else where on the web I've found that I can get the 4.111:1 at a reasonable price - last time I checked it was two or three times the current amount. Plan is to fit another vehicle's diff to the rear of my subi and run an air locker - this way I can still safely use my AWD in the snow/really slippery conditions without the rear end sliding out as it would with a welded or auto locker. Cheers Bennie Link to comment Share on other sites More sharing options...
