djellum Posted December 26, 2012 Share Posted December 26, 2012 Hey, prep'n for a Weber swap in the next week or so, so I put a fuel pressure gauge inline to the carburetor just to see where it sits. it pulses quickly between a little above 2psi and 3 psi. question 1) is the pulsing a sign of fuel system problems? It is a cheap gauge so I wouldnt rule out some slight inaccuracy. question 2) is the spike to 3 psi what I should consider the fuel pressure? or the low spot? Im guessing that since it pulses very fast it wont make a difference since the bowl will still have fuel, and im not going over the max pressure required. question 3) is there anything I can do to make this more stable. My initial plan was to run a return line filter, so I can restrict the return a bit to try to get the pressure up to 3.5ish. I can also run dead ended since the pressure isnt over the max. I just got the Weber Haynes manual so ill check it out tonight, any advice would help though. Link to comment Share on other sites More sharing options...
skishop69 Posted December 27, 2012 Share Posted December 27, 2012 Pulsing at low pressures means nothing to a carb. It's the normal function of pump operation on older rigs. It'll be fine. Link to comment Share on other sites More sharing options...
