1990 Subaru Loyale Wagon 4WD
I assume you mean the T-belt covers, and pull off the easy-side covers (since the middle one requires you to remove the crank pulley) and 1) make sure they're still spinning, and 2) make sure the timing is still on.
Sometimes, the rear covers are old/warped and when pulled together with the front cover, can bind on the cam sprocket causing it to seize and either jump the belt or break it..
