lmdew Posted December 30, 2012 Share Posted December 30, 2012 A friend picked up a 01 Legacy at a pretty good price. It's leaking oil on the HG so he's going to replace them. He asked if there was a better Improved HG. I said I'd stay with Subaru HG's. Anyone know any different? Any other hints for a quality HG job on a 01 2.5? Thanks Larry Link to comment Share on other sites More sharing options...
idosubaru Posted December 30, 2012 Share Posted December 30, 2012 resurface the heads and use the Subaru EJ25 Turbo headgaskets. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 30, 2012 Share Posted December 30, 2012 Yep - 255/257 gasket. GD Link to comment Share on other sites More sharing options...
ivans imports Posted December 30, 2012 Share Posted December 30, 2012 I use stock gaskets but do not trust the coatings on them i coat every one with avionic form a gasket every time to insulate the gasket from the heat and oil and coolant thiss seems to holdup have cars with 300000kms on them after headjob and no leaks small step but makes a difference over a 100 headgasket jobs thiss year and no combacks Link to comment Share on other sites More sharing options...
987687 Posted December 30, 2012 Share Posted December 30, 2012 The headgasket you want is subaru part number: 11044AA642. Link to comment Share on other sites More sharing options...
lmdew Posted December 31, 2012 Author Share Posted December 31, 2012 Thanks for the info. Link to comment Share on other sites More sharing options...
logic23 Posted January 3, 2013 Share Posted January 3, 2013 do y'all know the part number of the 2.5 turbo gasket? is it thicker and does it mess with the compression ratio? Link to comment Share on other sites More sharing options...
987687 Posted January 3, 2013 Share Posted January 3, 2013 do y'all know the part number of the 2.5 turbo gasket? is it thicker and does it mess with the compression ratio? I listed the part number a few posts up. The sti gasket is 0.5mm thick vs 0.75mm. So you get a very slight compression bump and gain probably 1-2hp. The difference is negligible, but it's a much better gasket. Link to comment Share on other sites More sharing options...
logic23 Posted January 4, 2013 Share Posted January 4, 2013 thanks for the info.....much appreciated Link to comment Share on other sites More sharing options...
