Uberoo Posted January 7, 2013 Share Posted January 7, 2013 So I am replacing my brake master cylinder on my 81 hatch offroader. No matter how I tried to bleed the brakes I would always loose my brakes after a short while. The last time I bled the brakes before something clicked in my head I managed to get 3 outta 4 brakes working at least for a little bit then back to nothing.So anyway I take out the old one with fluid in the reservoirs still and press in the plunger.Nothing comes out of the "F" port on the MC but fluid squirts out of the "R" port.The car has a diagonal split as I am sure you all are aware of. LF to RR kinda thing.So how exactly did I get 3/4 brakes working when only 2/4 should have worked at all? I'm just a bit stumped on this.If it makes any difference It was one of the rear brakes that didn't work. also my car originally came with a 13/16 MC and rear drums.My front brakes were leaking from the handbrake assembly so I replaced those and did the rear disk conversion at the same.It is worth noting that I have EA82 front suspension/brakes on my 81.My question is the replacement MC is 3/4" bore with the bleed screws on opposite sides as the old one.No big deal.I am just wondering how that smaller MC will affect braking.I know that smaller MC's increase line pressure at the expense of needing more travel to displace a similar amount of fluid, so how will that work with the EA82 vented rotors up front and disks in the back. Link to comment Share on other sites More sharing options...
skishop69 Posted January 7, 2013 Share Posted January 7, 2013 You should be using a bigger MC so the volume is correct for the system. It sounds to me like you have two problems. First, the MC is toast. It's internally bypassing so you're getting little to no pressure on that circuit. Second, I'd say that the rear caliper that isn't working is binding. It could be the piston or the slides. If the piston is sticking, what little pressure the MC is developing on that circuit is going to the opposite front caliper giving the impression of working. Link to comment Share on other sites More sharing options...
Uberoo Posted January 7, 2013 Author Share Posted January 7, 2013 So what is a larger MC that will fit?Arn't 4x4 EA81 and EA82 MC's 13/16? Link to comment Share on other sites More sharing options...
skishop69 Posted January 8, 2013 Share Posted January 8, 2013 He said the replacement was smaller. What I meant was he should be using the 13/16. How he got a smaller one, I'm not sure. Of course, the aftermarket world is full of oddities. Volume is pretty important when changing wheel cylinders to calipers. It's a good thing that Subaru over engineered a lot of things. Link to comment Share on other sites More sharing options...
ivans imports Posted January 8, 2013 Share Posted January 8, 2013 have you bleed it from the bleeders on the master ? they have to be bleed before the rest of car can be Link to comment Share on other sites More sharing options...
Uberoo Posted January 9, 2013 Author Share Posted January 9, 2013 After getting everything bled I think I need to get a new MC with at least 13/16 or better.The 3/4" seems to bottom when I get about 5/8 braking effort.A full on "panic stop" stops the car like I am just using the handbrake.Which is less than stellar with 4 wheel disk brakes. not sure why rock auto sent a 3/4" instead of 13/16".. Link to comment Share on other sites More sharing options...
naru Posted January 9, 2013 Share Posted January 9, 2013 Uberoo said: After getting everything bled I think I need to get a new MC with at least 13/16 or better.The 3/4" seems to bottom when I get about 5/8 braking effort.A full on "panic stop" stops the car like I am just using the handbrake.Which is less than stellar with 4 wheel disk brakes. not sure why rock auto sent a 3/4" instead of 13/16".. You got a 3/4 one for an 81 brat,not a 13/16 one for an 81 hatch. Link to comment Share on other sites More sharing options...
ivans imports Posted January 10, 2013 Share Posted January 10, 2013 the smaller the bore the more psi it creates the biger the bore the more volume it makes on the race buggy i whent from 1-5/16 to a 3/4 to increase the preshure. The biger one could not hold the car back but the smaller one did. I do not think the size of master is that important. Is it posibble that has a seized wheel cly or addjusters in wrong or air traped somwere Link to comment Share on other sites More sharing options...
