ThatSubaruKid Posted January 8, 2013 Share Posted January 8, 2013 I want to get some different tires for my brat. I will be lifting it soon and was just curious as to what is the best size tire for a 1st gen Brat with a 4 inch lift? Link to comment Share on other sites More sharing options...
turbosubarubrat Posted January 8, 2013 Share Posted January 8, 2013 ThatSubaruKid said: I want to get some different tires for my brat. I will be lifting it soon and was just curious as to what is the best size tire for a 1st gen Brat with a 4 inch lift? you can run 195/75/14r stock with very little rubbing on a stock brat. so do a six lug swap by redrilling the hubs and you can run the same rims as toyota's, mazad's, chvev's, ect. so you can run some 15 inch rims with what ever tires will fit or you can make them fit. Link to comment Share on other sites More sharing options...
ThatSubaruKid Posted January 8, 2013 Author Share Posted January 8, 2013 Sweet, I'll have to read up on doing a 6 lug swap next. Link to comment Share on other sites More sharing options...
Markus56 Posted January 11, 2013 Share Posted January 11, 2013 turbosubarubrat said: you can run 195/75/14r stock with very little rubbing on a stock brat. so do a six lug swap by redrilling the hubs and you can run the same rims as toyota's, mazad's, chvev's, ect. so you can run some 15 inch rims with what ever tires will fit or you can make them fit. Those tires will fit on a stock gen 1? hmm... I know they fit on gen 2 and gen 3, but always thought they would rub on the back of a stock first gen. Link to comment Share on other sites More sharing options...
Yaron Posted January 14, 2013 Share Posted January 14, 2013 I tried 195/75/14 on pugs on when i had my GEN 1 wagon and it rubbed the back arches. The largest size I could fit (which also required some banging on the rear arches) is 175/75/14. Now the wagon is gone and a BRAT has replaced it, i will re-try the 195 tires on it in a few weeks and update. Link to comment Share on other sites More sharing options...
