97Bake Posted January 9, 2013 Share Posted January 9, 2013 I've looked and I can't really find anyone else with my set of facts- the (younger) principal driver of the car said she felt a pop (in the drive-thru line at Starbucks, of course) and the "car wouldn't go without shaking". After taking a look and test drive, then looking up the symptoms, it seems that it's "torque bind", or something related. I read all kinds of stuff, then went and had the trans fluid changed, which improved the cars performance greatly. The following day the torque bind had returned. I saw the references to plugging a fuse into the FWD slot, found it and did so. With the FWD fuse installed, the car won't move- it just shudders. So it seems the FRONT clutch or solenoid or whatever is out, right? I sure have learned a lot lately- R&R'd a (rebuilt) CV axle recently, so I have some basic ability. Can anyone say for certain what probably broke before I crawl under the car? Link to comment Share on other sites More sharing options...
nipper Posted January 9, 2013 Share Posted January 9, 2013 You popped a cv joint. I bet (be careful) if you put the FWD fuse in the holder, put the car in drive (do not stand in front of the car) and look at the drive shafts, you will see one spinning like mad and the other just sitting there waiting for something to happen. It is the one that is spinning like mad that is broken. The rear wheels are essentially driving the car, the vibration your feeling is the bad CV Joint, and the fluid change, all soobys love fluid changes. Link to comment Share on other sites More sharing options...
97Bake Posted January 10, 2013 Author Share Posted January 10, 2013 OK I just did that- I couldn't see anything spinning, but I could see some significant vibration of the driver side inner boot- I guess that would mean another CV / shaft replacement. I did the other side about 2 months ago... Link to comment Share on other sites More sharing options...
97Bake Posted January 10, 2013 Author Share Posted January 10, 2013 ...I guess that explains why the car rolls in park, eh? Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted January 10, 2013 Share Posted January 10, 2013 shop for EMPI axles at RockAuto, or reboot a subaru axle from a junkyard. typical rebuilts from car parts houses are notoriously variable in quality. try not to run it much if at all or the seal in the diff may get compromised. Link to comment Share on other sites More sharing options...
nipper Posted January 10, 2013 Share Posted January 10, 2013 ...I guess that explains why the car rolls in park, eh? It is always the little details they leave out .... Link to comment Share on other sites More sharing options...
nipper Posted January 10, 2013 Share Posted January 10, 2013 OK I just did that- I couldn't see anything spinning, but I could see some significant vibration of the driver side inner boot- I guess that would mean another CV / shaft replacement. I did the other side about 2 months ago... Broke at the inner CV joint. Just replace the axles, don't rebuild them. Use the source cited. Link to comment Share on other sites More sharing options...
97Bake Posted January 10, 2013 Author Share Posted January 10, 2013 OK. replaced drivers side axle... whatever the problem is, it's not that. Vibration seems to be in 1st & reverse, it can take full throttle in 2nd, 3rd, etc. Link to comment Share on other sites More sharing options...
nipper Posted January 10, 2013 Share Posted January 10, 2013 So the car can move on its own now? If so, where can you feel the vibration. Is it throughout first gear or only towards the bottom middle or end of the rpm range? Does it happen in all gears at that rpm or only first and reverse? Wht happens when you go to parking lot and make a full lock turn at idle speed? Do all your tires match Are all the tires properly inflated? Link to comment Share on other sites More sharing options...
