UMT Posted January 10, 2013 Share Posted January 10, 2013 99 Impreza Outback Sport: all of a sudden, my speedo is dark from 0 - 30 MPH...! I'm assuming a blown led??? How hard to remove dash and replace? Thanks, UMT Link to comment Share on other sites More sharing options...
ivans imports Posted January 10, 2013 Share Posted January 10, 2013 try giving the top of console a cupple good wacks might turn the light back on Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 11, 2013 Share Posted January 11, 2013 Pretty sure the cluster lights are just 194 or 168 wedge bulbs. Cluster isn't hard to remove. I have one that is intermittent on the 70-140 side of mine. Doesn't bother me because I hardly use that half of the speedometer anyway. But the low side, yeah I would pull the cluster out to replace that. Link to comment Share on other sites More sharing options...
charm Posted January 12, 2013 Share Posted January 12, 2013 They're a couple bucks each from the dealer. As easy as it is to remove the cluster, there's no sense in doing it more than once with the bulbs being as affordable as they are so replace all of them while you're in there. Took me about 15 minutes having never done it before. It's not too many screws and then just a little wiggling and a couple plugs. Link to comment Share on other sites More sharing options...
UMT Posted January 14, 2013 Author Share Posted January 14, 2013 They're a couple bucks each from the dealer. As easy as it is to remove the cluster, there's no sense in doing it more than once with the bulbs being as affordable as they are so replace all of them while you're in there. Took me about 15 minutes having never done it before. It's not too many screws and then just a little wiggling and a couple plugs. 99 Impreza Outback Sport: Took a quick look at the dash.. Have never had to remove anything like this before... I take it the 'bolts' are underneath the dash? How about a quick lesson, tips on how to remove? Thanks, UMT Link to comment Share on other sites More sharing options...
