Pooparu Posted January 10, 2013 Share Posted January 10, 2013 http://item.mobileweb.ebay.com/viewitem?itemId=221172380015&index=2&nav=SEARCH&nid=69144727509 eBay link for early dash Do you think I can get this to fit in my 1977 coupe? Link to comment Share on other sites More sharing options...
Leeroy Posted January 11, 2013 Share Posted January 11, 2013 I do not see why not! There are basically only 4 bolts to undo to remove the dash and I do not believe the welded in mounts for these changed from '73 to early '77. I should qualify that by saying I only have experience with the '74 and '76 dashes... Never seen the early '72 - '73 dash in person so you would have to check the mountings carefully to make sure they match. I think the bigger problem would be the different wiring harness used.... Link to comment Share on other sites More sharing options...
The Beast I Drive Posted January 11, 2013 Share Posted January 11, 2013 It should fit. You can come check out the dashes on the Tailgate wagons vs. the lifted wagon if you want to be 100% sure, but they are the same body so it should work. -Bill Link to comment Share on other sites More sharing options...
