I checked the steering on my Impreza and it is 3.2 turns lock to lock. For rally purposes, I'd like to get it to around 2 turns lock to lock. Any models of the Subaru that have a quicker steering ratio? Or can one modify the rack and pinion to get the desired ratio?
  987687 said:
According to cars101, the 05+ sti have a 2.6 turn lock to lock steering ratio.
Probably 04 as well, but the way cars101 is laid out is a bit funky for the impreza. But it does have that listed for the 05 and 07.
I went to cars 101 but neglected to do years other than my 2002 OBS. It didn't have any info; I tried a few other years also but didn't get into the STi or much newer cars.
All 93-05 imprezas have a 16.5:1 steering ratio
The 04-07 STI and 06/07 WRX have 15:1 steering ratios
Subaru changed the design of the crossmember and steering rack in 2005/2006.
So the only 15:1 ratio rack that will bolt into any 93-05 impreza, is the 04' STI.
If you change the crossmember you can use a newer style rack.
(Any 02-07 impreza rack swapped into a 93-01 impreza will need a custom u-joint.)
