torxxx Posted January 23, 2013 Share Posted January 23, 2013 (edited) hey guys, just got a 5 speed put back together after having the gear shop in town replace the syncros and the bearings in a 5 speed. I split the case myself and dropped the gear sets off to them. I've done about a dozen of them and have had 100% success with everything working after. Now comes the odd part, on the bench I'm almost positive I felt it shift/click into 4th gear. Got the tranny back into the car and went to check to see if it had all gears with teh linkage and shifted hooked up. All gears but 4th (4th was the problematic gear that the customer wanted fixed) There is no position on the shifter for 4th, almost like the guy forgot to put the shift collar for 3/4 shift but everything appeared ok when I got the gear sets back from the shop Is there anything I could have mixed up that would keep 4th from showing or even clicking into gear? Edited January 23, 2013 by torxxx Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 24, 2013 Share Posted January 24, 2013 Perhaps the shear pin in the shift fork sheared and the fork will only go forward? Are you sure the fork centered between the collar correctly? Link to comment Share on other sites More sharing options...
torxxx Posted January 24, 2013 Author Share Posted January 24, 2013 tore the tranny back down, the company that did the work refuse to admit they did the work even though I have a receipt for it. When the guy put the brass wear ring back in in, he either didnt replace it or bent it. The shift collar will not engage to 4th gear what so ever. So now I gotta find someone with a press and a bearing buddy so I can pull the thrust washer off and see what exactly the guy broke. Sad thing is the guy who did the work has supposedly been doing gear work for 35+ years Needless to say, I guess I'm going to be teaching myself how to rebuild gear shafts. Link to comment Share on other sites More sharing options...
torxxx Posted January 25, 2013 Author Share Posted January 25, 2013 Got everything rebuilt/replaced on the main gear shaft. was surprised at how easy they are to rebuild. Got me my own bearing separator coming in the mail and will be ordering my 4.44 R&P this weekend. Now I can get motivated to build my 5MT for my own outback and get that R&P installed. oh and weld up that center diff.. hehehe how bad is my car gonna drive if I weld up the front diff? really thinking about building 2 trannys (one with stock open diff and then my play tranny with a welded front and center diff) Link to comment Share on other sites More sharing options...
nipper Posted January 25, 2013 Share Posted January 25, 2013 If you weld your front diff? Do you like the front end of your car? You will find that steering thing to really be overated if you do that. Link to comment Share on other sites More sharing options...
