greggbrat Posted April 12, 2004 Share Posted April 12, 2004 I have an 82 brat getting a BYB 4/3 lift. I found a set of 15" pug steel rims but now I am having a problem finding affordable tires to fit. This rig will be used for rock crawling so I need to keep low gear ratios as much as possible. I am basically looking for the follow specs: - Mud Terrain tires - Maximum of 26" outside diameter (to fit on 15" pug steel rims) - Fairly inexpensive Does anyone know of my options? I have found several solutions for 14" rims........the 15" rims seem to only have options for a minimum of 215/75/15 which equates to 27.7" outside diameter. Please Help!!!!! Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 12, 2004 Share Posted April 12, 2004 Rock Crawling? You will need lower gearing, and more than a 3" lift in my opinion. Interco Makes the swamper radials in a 205/75R15 I think. GD Link to comment Share on other sites More sharing options...
greggbrat Posted April 12, 2004 Author Share Posted April 12, 2004 I am putting the 5sp D/R in my brat and a 3.9 LSD but I have no other choices for regearing. I know the Interco SSR's are available but they are still too big and too expensive. I dont need any more lift than the BYB 4/3......I have been rock crawling for years.......its more about skill as long as you have some clearance and decent gearing......which is why I dont want to go larger than 26" tires. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 12, 2004 Share Posted April 12, 2004 I don't think there is really anything with a decent tread pattern smaller than a 205.... unless you go to a snow tire, but I haven't seen anything agressive enough there either. You may have to find some 14's. It is about skill, but your going to want a locker instead of that LSD, and probably some power steering. And a BIG left leg for managing the clutch. GD Link to comment Share on other sites More sharing options...
bushbasher Posted April 12, 2004 Share Posted April 12, 2004 I found some aggressive 205/75/15 snow tires once, they were more aggressive than a bfg at, probably on par with a bfg mt. They were pretty much no-name brand tires. You wouldnt find these kind of tires on the net, you'd probably have to go searching tire stores. But I think thats as good as you can get in 205/75/15. A 215/75/15 is going to be smaller than its rating, most tires are this way. I have a few different 225/75/15s that all measure out to only 27", maybe a hair more. I would go with a 215/75/15 because even though you might lose a bit of gearing, you have more tire options. Plus there will be more sidewall, which will allow you to air down more. Just to clarify, thats a lincoln locker, or welded diff, that GD is talkin about. Link to comment Share on other sites More sharing options...
greggbrat Posted April 12, 2004 Author Share Posted April 12, 2004 I am about ready to sell my 15" pug steel rims.......or trade for 14" pug steel rims. There are so many more choices for aggressive tires in the 14" range. I found some really good looking Mud Terrain tires for about $70 each in the size of 215/75/R15.......but I still think that is too large for me. I dont have an issue with trimming the fenders but here in Colorado the trails get steep......I really need to keep my gearing as much as possible. Link to comment Share on other sites More sharing options...
