92 Loyale A/C idler pulley...
This one has got me annoyed to start this off...:slobber:
I CANNOT:banghead: find anything online at local stores or anything. Granted running one belt seems to not be an issue but i'd feel better with both as was intended.
Simply, where do I find this pulley and the hardware associated with it. (I.E. Everything but the actual bracket)
Thanks!!!!:headbang:
I replaced the bearing in one of those pulleys when I was tracing a bearing noise. I still have it, it has about 5000 miles on it. I just recently pulled it because I am doing an EJ swap in that wagon.
i would do that...but it appears to be damaged (The bolt)
