Dinky26 Posted January 29, 2013 Share Posted January 29, 2013 Okay, I'm thinking that I really don't want to put these bolts back in. Where do you recommend one gets new bolts? Any hardware store okay? Grade 8 a good idea, or go with the regular grade bolt?[/img] Link to comment Share on other sites More sharing options...
idosubaru Posted January 29, 2013 Share Posted January 29, 2013 could put them in some parts cleaner or wire brush them and coat the threads good, and clean out the threads in the heads so your new bolts don't pick up old contaminants. or possibly someone on here could send you some? i've replaced them before and the places I went never had the right length, of course I could get close enough to work with. Link to comment Share on other sites More sharing options...
Dinky26 Posted January 29, 2013 Author Share Posted January 29, 2013 I just ordered a set from Subaru here in town with gaskets to go with em. Link to comment Share on other sites More sharing options...
ivans imports Posted January 29, 2013 Share Posted January 29, 2013 i take a 8-1.25 die and clean the threads with that and be like new Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 29, 2013 Share Posted January 29, 2013 Wire wheel and they will be fine. GD Link to comment Share on other sites More sharing options...
MilesFox Posted January 29, 2013 Share Posted January 29, 2013 Wire wheel does the trick. What you will find at the hardware store or anywhere else is that 1.25 thread bolts are hard to come by and impossible in any appreciable length. These bolts are rusty because they thread into the water passage on the heads. Coat them liberally with anti-seize compound Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 30, 2013 Share Posted January 30, 2013 I found New Bolts made of Good Quality Material and with the Exact Measurements, at the Local Napa Store: Link to comment Share on other sites More sharing options...
Dinky26 Posted January 31, 2013 Author Share Posted January 31, 2013 Nice, I bet they weren't $1.98 a piece:banghead: Except I don't have close access to a Napa store:mad: Autozone and ORielys ran them off:dead: Link to comment Share on other sites More sharing options...
Indrid cold Posted February 1, 2013 Share Posted February 1, 2013 (edited) Wire wheel... but... For hand power, a 1/2" copper fitting brush (plumbing section) is excellent for getting into tight areas (threads) and not as wimpy as a wire bristle tooth brush. Those don't look that bad ..... ? Edited February 1, 2013 by Indrid cold Link to comment Share on other sites More sharing options...
silverback Posted February 1, 2013 Share Posted February 1, 2013 Those of us in the Seattle area have "Stoneway Hardware". They have a broad selection of metric hardware: fine, coarse, small head, heat treated, studs, set screws, nuts (right hand & left hand nuts), stainless and so forth. Last time that I checked, the M8-1.25 bolts (grade 8.8) were available up to 110mm long. It is the biggest little hardware store in Seattle. This is where we save ourselves. The weekends always have European cars and bikes filtering in and out of the parking lot. Link to comment Share on other sites More sharing options...
NickNakorn Posted February 1, 2013 Share Posted February 1, 2013 It's hard to tell from the pics but are the threads the exact same pitch and shape? I'd rather clean up the old ones than risk an unknown quality of hardware - do they feel smooth when screwed in? (I might well be wrong but they don't look the same to me even with my specs on!). Link to comment Share on other sites More sharing options...
Dinky26 Posted February 2, 2013 Author Share Posted February 2, 2013 (edited) I'll have to check on those ??s, one thing is for sure though the two short ones or ones on the ends were not near as tight as the long ones. I ordered replacements from the Subaru dealership here in town, should be the same quality. I hope anyway.... I just felt like the ones I pulled out had to much pitting in them to be real trust worthy down the road. When it's been said on here that it is a b....tch to get them out if they break. I've seen some bolts over the years that were less compromised fail, in different uses of course, my dad always told me that if it looked like it might fail...go ahead and replace it cause you probably will later anyway. Edited February 2, 2013 by Dinky26 Link to comment Share on other sites More sharing options...
The Beast I Drive Posted February 2, 2013 Share Posted February 2, 2013 I usually don't reuse the bolts, I bought a length of B9 threaded rod in the right size and thread pitch and make studs, then I use stainless nuts. It can make it a pain to get the manifold off again someday, but I don't have to worry about stripping the threads in the heads. -Bill Link to comment Share on other sites More sharing options...
Gloyale Posted February 2, 2013 Share Posted February 2, 2013 Nice, I bet they weren't $1.98 a piece:banghead: IDK, have you priced long bolts at NAPA lately? I'll bet they cost more than the couple nickles one would expect to pay for bolts. Link to comment Share on other sites More sharing options...
Dinky26 Posted February 2, 2013 Author Share Posted February 2, 2013 No, I've not priced bolts at NAPA, don't have one close to check with. Link to comment Share on other sites More sharing options...
