axgutt Posted February 2, 2013 Share Posted February 2, 2013 '95 Legacy Wagon with 295,000 miles, auto tranny (replaced a little over 60,000 miles ago). At the end of a road trip we noticed a burning smell, and when we got home there was lots of ATF fluid leaking from somewhere. I moved it outside and let it sit for a week until I could buy a giant pan, jack it up and take a good look. Medium story short, when I start it up there is a steady stream of ATF fluid coming out where the driveshaft connects to the AT. I checked the ATF fluid before and after and it definitely dropped from medium to low in a couple of minutes. It stops dripping when the engine is off. So I looked in my Haynes manual and it sounds like it could be a bad extension housing seal. If that failed, would this happen so suddenly? It's certainly beyond my skill level to take this on myself. About how many hours of labor am I probably looking at for this $10 part? Is this something a general repair shop can probably handle, or a transmission shop? Unfortunately the mechanic I trusted retired last year. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted February 3, 2013 Share Posted February 3, 2013 So it's leaking from the very back of the transmission? Is it coming out of the driveshaft seal or is it forward of that? The extension/ tail housing seal shouldn't be too difficult to repair. Pretty sure it can be done with the trans in the car. Ill have to check out the FSM when I get home. Quote Link to comment Share on other sites More sharing options...
bstone Posted February 3, 2013 Share Posted February 3, 2013 You can do extension housing with trans still in car. Some of the bolts are a bit tough to get to. I can't say if it's the ext housing that is leaking but just confirming you don't need to drop the entire trans. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted February 3, 2013 Share Posted February 3, 2013 Two things: make sure it's not the cooler line leaking around the banjo bolt where it goes into the case. There also appears to be a plug on the extension housing for the transfer clutch pressure feed. Make sure it's not leaking there. Quote Link to comment Share on other sites More sharing options...
