91loyale59 Posted February 2, 2013 Share Posted February 2, 2013 so i have a 92 loyale with a two inch lift that is killing axle boots daily. i was going to drop my engine x member my radius rod and my tranny x member 1 inch along with extending my steering shaft 1 inch. i can not figure out how to drop the tranny x member and radius rod though. any help would be apprecated Link to comment Share on other sites More sharing options...
MilesFox Posted February 2, 2013 Share Posted February 2, 2013 There is enough length in the bolts to stack a few washers between the body Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 2, 2013 Share Posted February 2, 2013 When I installed The SJR 2" Lift Kit for the Front of my Subaru "BumbleBeast" I dropped the Engine's Crossmember 1½" Inches to let the Axles sit as Straight as Possible; The SJR kit came with Rectangular tubes, Strong enough to be Placed between the Body and the Crossmember. See: ~► http://www.ultimatesubaru.org/forum/showthread.php?t=117874&page=3 I also had to extend the Steering Shaft. Kind Regards. Link to comment Share on other sites More sharing options...
91loyale59 Posted February 3, 2013 Author Share Posted February 3, 2013 how much did you extend the steering shaft Link to comment Share on other sites More sharing options...
bratman18 Posted February 3, 2013 Share Posted February 3, 2013 91loyale59 said: how much did you extend the steering shaft The same amount that the subframe spacers were. Link to comment Share on other sites More sharing options...
