Just finishing doing a head gasket on a 96 OB 2.5. I got the timing belt installed and the timing marks were correct after pulling the pin and doing the 90 degree counter clockwise, 180 clockwise turns. I figured everything was set. Car wouldn't start. It turns over uneven, sometimes it sounds good and then sometimes it sounds week.
Battery is fully charged, everything is connected except alternator, PS, AC, purge canister, radiator.
Any ideas before I pull a head off to see if I bent valves.
maybe it slipped a tooth. even one tooth off and it sounds bad starting from the low compression. double check timing by counting teeth. on the DOHC, its 51 teeth on driver side, 54.5 teeth on pass side from crank to top cam notch.
also in case you didn't do this, loosen tensioner bolts and wedge a screwdriver to lever the tensioner to the pass side, and tighten up the tensioner bolts. helps tighten up the belt. i rotate twice around clockwise to take up the slack before buttoning things up.
Edited by 89Ru
You missed a step, maybe used arrows instead of dots and hash marks(or something else is off), or the engine was already trashed.
Those are the only options.
I did find the service manuals elsewhere on this forum, downloaded and followed them. I put a straw in the #1 cylinder to find TDC. Aligned the double marks on the cam sprockets at the 6 o'clock position. The tb is tight all the way around. I'll do a compression test today. I didn't replace the cam seals, there was no leaks before.
The car ran great before, just had a head gasket leak.
  GeneralDisorder said:
You don't use TDC for timing belt alignment. You use the mark on the crank sprocket - which puts all four cylinders at exactly halfway up in the cylinder. If you did the belt at TDC then it's WAY off.
The crank mark is pointed at 0, so which mark should the arrow be pointed at. I guess I'm missing something here.
You can't time these at TDC.
Timing mark on the crank sets all pistons at half stroke. Look on the back edge of the sprocket at the reluctors for the crank sensor. 90 degrees counter clockwise from the TDC arrow. Line up the dot on the reluctor tooth with the notch on the top of the oil pump housing. Line up the notches on the cam sprockets with the notches in the rear timing cover.
Edited by Fairtax4me
If you used the arrows instead of the hash marks to line up for engine for the timing belt replacement, you almost certainly have bent valves. Although I would do a compression check anyway.
Chances are that you will be doing the head gasket again. Make certain that you use GENUINE SUBARU BRAND HEAD GASKETS ONLY. Many other posters have used aftermarket head gaskets and have lived to regret it. Save yourself from a giant headache.
I aligned the crank with the correct mark and it started, I didn't run I long as tranny fluid blew all over. I put a bolt in the hose thinking it would hold but when I started it again it just blew out. Ran find for the few seconds I did have it running. Tomorrow I'll do a compression test after I hook up the rest of the stuff.
Thanks guys.
do not plug tranny cooler lines will damage the anti drainback valve join them together with a tube to allow them to flow. Hope your valves survived have had to redo many belts that shops got wrong dont think that will have damaged anything. The mark on crank for belt timing indacates that all 4 pistons are at same height in block not tdc
I put everything back together and started it up. It runs great. I haven't done the compression test yet, spent about an hour trying to get one spark plug out and get the hose for the compression gauge in there so I gave up. My back was killing me. I'm very confident there are no bent valves. If it did have bent valves, wouldn't he motor be running ruff.
