presslab Posted February 6, 2013 Share Posted February 6, 2013 Yesterday my 4EAT ('88 GL-10, but figured best to post in new gen) trans went from perfect to sounding like a bad power steering pump (it's not the PS pump). It will make an engine speed related whirring sound that comes and goes. I thought it may be the torque converter but it still does it somewhat when I rev the engine in neutral, and also when the TC locks up on the freeway I can still hear it. So that leaves the oil pump, as it's engine speed and not road speed or gear dependent. I removed my inline filter and looked inside, it was just fine. Checked the fluid (it's a few months old) and it's fine. It looks like I can get to the pump after removing the diff housing. I'll probably upgrade to the newer housing as I currently have an adapter plate for my EJ20G, and it would be nice to get the newer torque converter. My questions are thus: Why would the pump fail? Do I need a certain diff housing to use a Legacy SS torque converter? Link to comment Share on other sites More sharing options...
presslab Posted February 7, 2013 Author Share Posted February 7, 2013 I have a lead on a WRX torque converter. Sounds like I can use that one with the WRX input shaft. I'd guess a N/A phase-II input shaft would work too, but I think the WRX one is stronger. Link to comment Share on other sites More sharing options...
idosubaru Posted February 7, 2013 Share Posted February 7, 2013 could it be a cracked flexplate..or the beginnings of one? Link to comment Share on other sites More sharing options...
presslab Posted February 7, 2013 Author Share Posted February 7, 2013 Something else that makes me think it's the pump is that when I pulled and replaced the filter, there was some air in the lines. When I started it in park, the noise became very loud for a second, the loudest ever, as I would imagine the air pocket reaching the pump. I suppose it could be the flex plate or the torque converter. In any case I'm pretty sure the trans needs to be pulled to solve the problem. It looks like I need to remove the pinion gear to get at the oil pump, which means removing the tail housing too. Has anyone ever replaced their oil pump? Link to comment Share on other sites More sharing options...
idosubaru Posted February 7, 2013 Share Posted February 7, 2013 i have seen folks on a board somewhere talk about replacing the oil pump, i just don't recall who or which one. Link to comment Share on other sites More sharing options...
CNY_Dave Posted February 7, 2013 Share Posted February 7, 2013 If it is the flex plate it might be visible through the cover used to access the torque converter bolts. On my H6 the TC is visible from below as well. Usually pumps only fail when someone doesn't seat the converter all the way. Link to comment Share on other sites More sharing options...
presslab Posted February 7, 2013 Author Share Posted February 7, 2013 I checked the torque converter bolts' tightness through the top access hole and I didn't see anything wrong. I did do an engine conversion a year and 10k miles ago, but I never removed the torque converter and the engine mated perfectly with no force. It's quite possible that the added power of the new engine has caused something to fail, but I can't think how more power would cause the oil pump to fail. The surprising thing to me is how sudden this noise has shown up. Link to comment Share on other sites More sharing options...
presslab Posted February 8, 2013 Author Share Posted February 8, 2013 I was hoping there would be more information out there, but it seems this is an uncommon problem. I'm going to have someone I know who owns a transmission shop listen to it today. Link to comment Share on other sites More sharing options...
Fairtax4me Posted February 8, 2013 Share Posted February 8, 2013 (edited) Flex plates don't whine. They might click, tick, or knock, and will probably make you think a rod is about to sprout. Probably the pump making noise. Pull the pan and check the pickup first. There is an o ring on the pickup screen that can let air get sucked in with the fluid and cause the pump to whine just like a steering pump will when the fluid is low. There may be another o ring higher up as well. Also just for giggles check the torque of the bolts that hold the valve body to the case. I have heard of valve body bolts coming loose (don't remember which car it was) and causing some weird problems. If the bolts near the pickup are loose air could get sucked in around the valve body gaskets. Edited February 8, 2013 by Fairtax4me Link to comment Share on other sites More sharing options...
presslab Posted February 11, 2013 Author Share Posted February 11, 2013 The trans guy listened to it and he wasn't sure what it was either. He said it was possibly the torque converter, but it wasn't consistent which made him wonder. He said the oil pumps rarely fail. He didn't think it was any kind of air getting sucked into the pump, as he said the inlet screen and valve body would normally be submerged anyway. If I rev the engine in neutral and then shift to reverse with the RPMs around 2500, the trans is very loud and I can even feel vibration in the shift lever that coincides with the noise. This also makes me think that it's not just sucking air. I'm not sure why reverse is louder than drive, probably has something to do with the line pressure. Anyway I guess I'll take out the trans and have a look at the torque converter first. If I see anything obviously wrong I will just move forward with upgrading to the WRX torque converter. Otherwise I'll dig deeper into the trans to see what's going on. Link to comment Share on other sites More sharing options...
CNY_Dave Posted February 11, 2013 Share Posted February 11, 2013 Are you sure the pan hasn't been slightly dimpled or bent-in? The pickup is very close to the pan and folks have had problems from the pan getting pushed in a seemingly minor amount. Link to comment Share on other sites More sharing options...
presslab Posted February 16, 2013 Author Share Posted February 16, 2013 The pan is perfect, as far as I can tell. I ran a straightedge across it and it was flat. I received the WRX converter, it looks like it will work. I'd like to get the WRX turbine shaft too but I might have to settle for a normal one. The WRX one is supposedly shot-peened for added strength. I'm on vacation for a month so this will have to wait until I return. Link to comment Share on other sites More sharing options...
Gloyale Posted February 17, 2013 Share Posted February 17, 2013 presslab said: . I suppose it could be the flex plate or the torque converter. In any case I'm pretty sure the trans needs to be pulled to solve the problem. It looks like I need to remove the pinion gear to get at the oil pump, which means removing the tail housing too. Has anyone ever replaced their oil pump? I've replaced the metal pump gasket. It was leaking. ( some shop had it apart and used a PAPER gasket in there!) You will need a phase I bell and torque conv. When you take apart. Pull the pan first. There is a washer behind the pinion shaft transfer gear that will fall off into the pan as you remove pinion shaft. It's a selective part to set pinion distance. Losing it is easy if you don't know it's there. Link to comment Share on other sites More sharing options...
presslab Posted April 16, 2013 Author Share Posted April 16, 2013 Thanks for the info! I've torn it all apart, and the oil pump looked just fine. I cut apart the torque converter and I noticed that the turbine had a bunch of play in the bearing, like 1/8". The newer model torque converters have an additional bearing there along with the new shaft. So hopefully that's the problem. I looked for that washer on the pinion shaft but I couldn't find it; I see that it's there in the diagram on the older ones. It seems the newer shafts like on my other '98 4EAT doesn't use a washer here. The pinion bearing was perhaps a little notchy, and I can see by the wear pattern the R&P was not setup right by whomever rebuilt it. There were no shims on the pinion, and it still needed to go further in, so I don't know what's up with that. The rebuild was shoddy, I could see where they chiseled off (then reused) the pinion nut, etc., so maybe they just left that transfer gear shim off. Anyway I've decided to just switch to 4.11:1 to help with the turbo lag, and because the old 3.7:1 pinion was worn funny. I swapped speedo gears too. I pulled the gear assembly from the '98 and put it in the '88 trans body. I could see little upgrades here and there, and my clutches/band were fairly worn; the '98 one is JDM and looked great inside. However I left the '88 low clutch as it had 6 plates vs 5. Are there any hidden gotchas with doing this? The newer trans had an anti-drainback valve fitted to the cooler line. This should fix the occasional problem of the car not moving until the converter fills back up. I swapped this to the old case, but I had to modify the banjo bolt as the old case had a deeper bore. The WRX converter seems to fit just fine, along with the WRX turbine shaft. I bought a new shaft as it was only $95 and supposedly stronger than the non-turbo ones. After all this I guess I should have just moved the old valve body to the new case, lol! Oh well. Fingers crossed that it will work when I get everything back together! Should be done in a few weeks, waiting on a few more parts. Link to comment Share on other sites More sharing options...
presslab Posted April 26, 2013 Author Share Posted April 26, 2013 Well it's mostly back together. The speedo cable broke, the plastic was brittle from sitting next to the turbo, so I'm still waiting for that. I ordered the newer style that's metal, hopefully it fits. I also need to swap my LSD into the 4.11 R160. I drove it anyway, FWD mode. The whining noise is gone, and it shifts great. It must have been the torque converter because the oil pump looked perfect, and I didn't mess with the valve body. It now has the WRX torque converter. Also I upgraded the rear mount to the newer '96+ style. This meant I needed to use the newer tail housing as it's different than the old ones. With the new mount the trans sits a little higher so the trans then hit the tunnel, so I "massaged" it. A little more ground clearance I guess isn't bad. Thanks for the suggestions guys. Link to comment Share on other sites More sharing options...
Fairtax4me Posted April 26, 2013 Share Posted April 26, 2013 Seems odd for a torque converter to fail that way, I guess something must have got into the bearings and damaged them. So you have a Franken-trans now! Glad to hear its working well! Link to comment Share on other sites More sharing options...
presslab Posted April 27, 2013 Author Share Posted April 27, 2013 Thanks! Well, I do have a TD05-16G at 19 PSI... That might explain the torque converter problem. This new one should be stronger anyway. Tomorrow I'm going to move the LSD chunk to the 4.11 pumpkin. Link to comment Share on other sites More sharing options...
