billrigsby Posted February 9, 2013 Share Posted February 9, 2013 Got this code, I checked all the lines for cracks/disconnetcs/plugs Checked that the Drain Valve was operating I have not got the code again but still whenI fuel up car starts a terribile missing and as soon as fueling is complete runs fine. It is worse the warmer it is, if it is real warm car dies and is tuff to restart. I am stumped, any suggestions? 99 2.2l impreza Link to comment Share on other sites More sharing options...
CNY_Dave Posted February 9, 2013 Share Posted February 9, 2013 Evap canister full of fuel? Link to comment Share on other sites More sharing options...
Fairtax4me Posted February 10, 2013 Share Posted February 10, 2013 The purge control valve could be stuck open. Check operation of the purge valve and try to blow air through it while it is opening and closing. You could also remove the evap air filter and fill up to see if the filter is clogged. If the symptoms go away, the filter is clogged. Link to comment Share on other sites More sharing options...
