Rear disks, gen 1. Possible?
well would anyone have a front disk setup that is trashed that I could play around with? It needs to be in kinda decent shape, enough where I can modify it and get it to work before I go and get a nicer set. Just in case I screw up. Oh and I will make a step-by-step process so it can be put in the USRM.
So I'd need the calipers and the rotors? Would there be anything else I'd have to get for it?
I put rear disk brakes on my 81 gen 1 brat. It was pretty easy all I had to do was grind a notch in the trailing arm for one of the caliper bolts. I got the entire brake setup, calipers. backing plates, hoses etc, off of a 88 4wd xt. Other than cutting the notch it was all a bolt in deal.
well hondasucks just said that ya need the front disks to make it work and lukr, you just said that youve actually did it. so are you saying that you did a rear disk to rear disk swap, or did you use the front setup like hondasucks just said was needed? oh well im nice and confused now. im REALLY lookin into this and would like the info. thanks.
Well I just got off the phone with Jason and here is what he said:
You use EA82T rear discs for the conversion. He said that all you need to do is bolt everything in and sometimes depending on the car, there is one bolt that will not go in all the way so then you have to grind a bit off of whatever its hitting so it'll go right in. Parts list consists of... calipers, rotors, and all the bolts from it.
So now I'm gonna be on the hunt for rear discs and do the conversion, take pictures and have it put in the USRM. I am also gonna be having the front suspension swap, seen in one of my other threads, in there also.
you need the calipers, rotors, and backing plate off of an 87ish GL10 wagon or equivelent and you will need to grind a little off the top of the trailing arm to get the caliper on and you will need to grind a little off the botom to get the backing plate down. other than that it is a direct bolt on. you will need to plumb your own brake lines. I got my set up this weekend fron the wrecking yard for less than 40$.total bill was 40$ with trailing arms spindles and head liner and mirrors off the 80 brat that was in there.
just the rotors, calipers, backing plates, the lines coming from it (the first and second flex lines and the hard line in between), and the misc. hardware you took off to remove the stuff. If Andrew brings up one of the turbed cars or even the carbed wagon I can point out what I am talking about this weekend or if need be I can try to find some info in some of my repair manuals.
