ivans imports Posted February 14, 2013 Share Posted February 14, 2013 had a bad power stering pump on my svx was able to sub in a 97 impreza pump with slight mods fixed the svx pump that was airating thiss is the 3rd svx pump have seen failed in the last 3 months. The preshure releif valve was worn on a angle and was bypassing making the fliud airated and foaming over the top of resivor. The impreza pump seems to work better with less leaks also i removed the return line cooler and its mutiple leaking conections now is leak free and works great Link to comment Share on other sites More sharing options...
torxxx Posted February 23, 2013 Share Posted February 23, 2013 I had looked at a impreza PS pump a few months back when I had an issue on my SVX. Funny cuz I asked on the SVX forums about interchangeability and they said no other pump would fit.. I ended up getting a reman pump off rock auto for 70 bucks or something, but I will be grabbing a impreza pump from work tommorow to have as a spare Link to comment Share on other sites More sharing options...
ivans imports Posted February 23, 2013 Author Share Posted February 23, 2013 you must look at the bolt pattern there is a large on and a small one mine used the small one so had to be a 97 or newer pump had to transfer the svx tank and use the impreza oring and slightly bend the line to accomadate the missing preshure valve switch. the new rack i put in whouldent stop airateing the fluid was the relif valve in the pump was worn on a angle and letting fluid bypass have done 3 with the impreza pump now works good and i have a pile of them good svx pump never seen one Link to comment Share on other sites More sharing options...
