2.2 to 2.5 Drivetrain/Dash/Harness Swap
Spacecadetchickn
Hey guys I have 2 issues.. After a swap I'm missing a control unit under the dash( not sure what it is/does... And I don't have the fuel pump working ...(might b related) please help...
Btw I took a 94 legacy sedan lsi chassis and put a 99OBW drivetrain(motor/trams/diff axles sturs hubs tires etc. aswell as the entire body harness fuel pump and dash.. Big frenchin project by yourself!( I did not use the OB gas tank, evap box, or drvr side sending unit.
I'll post some pics when I figure out how! Lol!
Ok so probably not my issue.... Now the only wires I cut were to the evap box in the back because it was mangled anyway. Does power go to the evap box then to the FP? Pump turns on with a hardwire but not connected normally. Also does not explain the absence of a CEL when ignition is on. Thinking with my fingers sorry.
