ThatSubaruKid Posted February 22, 2013 Share Posted February 22, 2013 (edited) Say I got some lift blocks fabricated for a First Gen Lego. Where would I put them. I know sounds like a dumb question..... Edited February 22, 2013 by ThatSubaruKid Link to comment Share on other sites More sharing options...
crazyman03 Posted February 22, 2013 Share Posted February 22, 2013 (edited) what size? are they strut lift blocks? if so, then on top of the struts ;-) edit: least, thats where i put mine.. though i have a Impreza.. same concept though.. i would think at least. -Justin Edited February 22, 2013 by crazyman03 Link to comment Share on other sites More sharing options...
Fairtax4me Posted February 22, 2013 Share Posted February 22, 2013 Depends on how big of a block you want to go with. I think you can get away with an inch and a half to two inch blocks just on top of the struts, but any more than that and you will have to make subframe and crossmember blocks as well. Dropping the subframe requires extending the steering shaft and possibly the dogbone mount bracket on the transmission. Link to comment Share on other sites More sharing options...
eulogious Posted February 22, 2013 Share Posted February 22, 2013 Like I mentioned in your other post, SJRs lifts come with 18 pieces total (I didn't use 2 because I think they are for manual trans cars, and mine is an auto). Engine blocks, trans blocks, rear sub-frame blocks, and strut blocks. Basically wherever there is a bracket under your car, you install a lift block, more or less. HTH! Link to comment Share on other sites More sharing options...
