mattocs Posted April 13, 2004 Share Posted April 13, 2004 On the 1996 Legacy Outback the tires are P205/60R15. If I get 16 inch rims and tires that were P205/60R16 would the speedometer be off? Or would they have the same circumference or whatever of the 15s...just a lower profile? Also, anyone know how much it costs to get a speedometer redone? I think 17s on an OBW would be neat. Thanks. Link to comment Share on other sites More sharing options...
SevenSisters Posted April 13, 2004 Share Posted April 13, 2004 You can Plus 1 with a P215/50R16 and be close. You need the shorter sidewall to keep the diameters about the same. Run a Google search on plus sizing and you should find one of the calculators that are out there. I'm sure a lot of the members here have done this and can speak about the wheel well clearances. Confirm everything with your tire dealer. Link to comment Share on other sites More sharing options...
mattocs Posted April 14, 2004 Author Share Posted April 14, 2004 Yeah. I think I might go with 16s...and even if I dont concider tire size the speedometer shouldnt be off to much. Link to comment Share on other sites More sharing options...
SevenSisters Posted April 14, 2004 Share Posted April 14, 2004 You have to go with the right 16" tire. The diameters have to be real close. You'll need the smaller (50) aspect ratio to accomplish this. If you're tires are off too much (and I can't answer how much is too much), the ABS algorithim will not give the braking performance it was intended to. The engine and automatic transmission sensors may also get confused and cause drivability issues. Check with a tire dealer to get the right set up and enjoy. Link to comment Share on other sites More sharing options...
lmdew Posted April 14, 2004 Share Posted April 14, 2004 The Stock WRX wheels and tires have been fine on my 98 Outback. NASIOC is the place to pick them up. $300 + shipping is the norm with very low milage. Some get lucky and pick them up for close to $200. Link to comment Share on other sites More sharing options...
simpreza2 Posted April 14, 2004 Share Posted April 14, 2004 http://www.miata.net/garage/tirecalc.html You can use the tire calc to find the right size. Link to comment Share on other sites More sharing options...
