Loyale/EA82 strut components
Are the front and rear use the same size bump stops, and strut boots? Also, are 2wd and 4wd REAR strut bushings the same? I'm looking into buying new stuff to go with my new struts an springs, and I want to make sure I get the right stuff. Thanks for the help!
The front suspension has modified MacPherson struts, and the back uses coil-over-shocks.  Very little in common.
Yeah I do know that. I have had many sets, in and out of a car. But I'm unsure if the strut boots, and the bump stops fit between the front and rear, or if there are different.
