newgen85brat Posted March 9, 2013 Share Posted March 9, 2013 Okay, I pulled my motor and forgot to disconnect the resistor that goes from the positive side of the coil to the ground on the engine. The unit ripped the wire off flush and cannot be fixed. It has the following markings 0169-17 150-05. What is this for? Will it still run? Where can I get it? Thanks. Link to comment Share on other sites More sharing options...
mikaleda Posted March 9, 2013 Share Posted March 9, 2013 If it is what I think it is this thread may help you http://www.ultimatesubaru.org/forum/topic/136409-what-is-this-little-capacitor-looking-thing/ Link to comment Share on other sites More sharing options...
Gloyale Posted March 9, 2013 Share Posted March 9, 2013 Condenser. Acts as a buffer for the voltage backup on the primary windings, until the ditsy trips the jump to the secondary(spark discharge) You will need one. Can be for almost anything. Just needs to be a condensor. Link to comment Share on other sites More sharing options...
NorthWet Posted March 9, 2013 Share Posted March 9, 2013 (edited) Condenser. Acts as a buffer for the voltage backup on the primary windings, until the ditsy trips the jump to the secondary(spark discharge) You will need one. Can be for almost anything. Just needs to be a condensor.:Edit :Edit: Missed an important part of the post. My response is irrelevant for electronic ignitions. Thanks, Mikelada! :endEdit Not quite accurate. You do need one, but it should be one that is matched to your coil. Otherwise, excessive points burning will occur due to flyback high-voltage from the primary windings trying to discharge across the gap as the points open. It does not need to be a exact match, but it should be. Edited March 9, 2013 by NorthWet Link to comment Share on other sites More sharing options...
mikaleda Posted March 9, 2013 Share Posted March 9, 2013 Not quite accurate. You do need one, but it should be one that is matched to your coil. Otherwise, excessive points burning will occur due to flyback high-voltage from the primary windings trying to discharge across the gap as the points open. It does not need to be a exact match, but it should be. 85 brat has electronic ignition Link to comment Share on other sites More sharing options...
NorthWet Posted March 9, 2013 Share Posted March 9, 2013 85 brat has electronic ignition Oops!!! I hate it when this happens. Edited my post to reflect my error. Thanks! 1 Link to comment Share on other sites More sharing options...
Gloyale Posted March 10, 2013 Share Posted March 10, 2013 My bad too. I was thinking points. That piece in your brat is RF suppression. Link to comment Share on other sites More sharing options...
mikaleda Posted March 10, 2013 Share Posted March 10, 2013 That's what I thought, the link I posted is about the rf suppressor on a 86 brat. It is not necessary it just keeps the electircal noise out of your radio. 1 Link to comment Share on other sites More sharing options...
newgen85brat Posted March 12, 2013 Author Share Posted March 12, 2013 Thanks guys! Link to comment Share on other sites More sharing options...
