I am working on a friends 1992 Subaru legacy and she was given a 1.8 motor from an impreza because her engine was blow, my question is can I just swap the engine harness and have everything be ok? will it run? will it run bad? will it pass Colorado State Emission Laws?
what he said, it's very easy.  no wiring swap.
remove the entire intake manifold with wiring off the EJ18.
install the EJ22 intake manifold (with new gaskets) onto the EJ18 engine - installing the knock sensor while you're at it.
done.
I'm assuming they both have EGR, i think EJ18's always do so you should be fine...
good time to just get a new knock sensor off ebay for $20, they fail fairly often.  i'd also be installing a new timing belt kit - $80 off ebay for all new belt, tensioner, pulleys.
