doc47 Posted March 17, 2013 Share Posted March 17, 2013 Where is the fill plug for the front differential on this machine? I've located the drain but can't find the fill. (And know by bitter experience not to drain the oil until you've determined you can get to and unscrew the fill !! Don't ask how I know this...!!) Second Q: Will it be necessary to use a pump to get the new oil in or is a gear oil bottle with a "squirt" tip sufficient? Thanks in advance. doc Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted March 17, 2013 Share Posted March 17, 2013 (edited) no fill plug. If manual, they share fluid and are filled through the dipstick tube. if auto, the diff's dipstick in on the other (right) side from the auto dip stick. Also filled thru the tube. I went slowly and used one of these; Edited March 17, 2013 by 1 Lucky Texan Link to comment Share on other sites More sharing options...
doc47 Posted March 17, 2013 Author Share Posted March 17, 2013 There's a dipstick for that sucker? And I haven't been checking it? Holy s--t! And I thought I took good care of my vehicles. (Just bitch-slapped myself!) Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted March 17, 2013 Share Posted March 17, 2013 I guess you have an automatic? sometimes the stick's handle is covered in grime. Look lower and a little farther back, (opposit side) from the auto's dipstick. Link to comment Share on other sites More sharing options...
torxxx Posted March 17, 2013 Share Posted March 17, 2013 make sure to replace that O-ring on the dipstick when you do find it. The oring shrinks and will allow gear oil to bubble out of there, dripping directly down onto the cat converter. I swap out that O-ring any time I service a trans Link to comment Share on other sites More sharing options...
tojo Posted April 26, 2013 Share Posted April 26, 2013 (edited) We just bought an automatic '01 Forester S with 136k for $3k and there is a scrubbing scraping noise whenever rolling and only when you push gas. Recommended transmission shop with Subaru experience pinpointed the noise to the differential and suggested the bearing is bad. Don't know how far into it they got but the repair will cost $750, does all this sound on the level? Edited April 26, 2013 by tojo Link to comment Share on other sites More sharing options...
Gloyale Posted April 27, 2013 Share Posted April 27, 2013 We just bought an automatic '01 Forester S with 136k for $3k and there is a scrubbing scraping noise whenever rolling and only when you push gas. Recommended transmission shop with Subaru experience pinpointed the noise to the differential and suggested the bearing is bad. Don't know how far into it they got but the repair will cost $750, does all this sound on the level? No. Your getting hosed. I'd check wheel bearings first. Or even possibly the brake rotor backing plate being a bit bent and touching the rotor. (possibly under load becuase of bad wheel bearing letting hub shift in knuckle.) Subaru front diffs almost never have bearing failure. Not in the side outputs. Occasionally the pinion shaft bearing will go, but then you get gear whine, and shavings in the diff fluid. This is ussually on turbo or 6cyl cars too, not NA 4cyl. If you are really considering front diff work, drain and check the fluid first. If the bearings in diff are the cause of the noise, there will be ALOT of shiny shavings in the diff oil. Link to comment Share on other sites More sharing options...
