lmdew Posted March 17, 2013 Share Posted March 17, 2013 Anyone know the difference in the knock sensors that plug into a harness right at the sensor and the ones with the built in lead? I know there is only one pin up at the top of the lead but two at the sensor. I'm thinking the other one is shielding. Thanks, Larry Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 18, 2013 Share Posted March 18, 2013 No difference in the way the sensors work AFAIK. Just different plugs. Should be as to swap the single lead plug at the engine harness end to match either sensor type and it should work just fine. Link to comment Share on other sites More sharing options...
