EA82 Antifreeze leak
Mmm, The secos photo seems to show that the water found the way in between head cylinder and gasket.
You must clean al least that part of the engine and then re check or take some new photos for us to help you. But it will be easier if the engine is clean to detect where it come from.
intake, thermostat, or throttle body gasket
+1... + little hose running from under the carb/throttlebody to the thermostat housing.  Lots of leak possibilities, the head and headgasket have nearly 0 chance of being the source for an external leak.
If I had to guess, the leak is running down into the sparkplug pockets on the head and then draining out through the drains in the head casting (which is why those drains are there).  Look for a coolant trail running into the rear sparkplug pockets.
