dssenne Posted March 28, 2013 Share Posted March 28, 2013 I bought a used 1999 Outback Limited that didn't come with any remotes for the keyless entry. I plan on buying a couple replacements, but in the meantime, is there a way to turn off the "audible signal option" (honking horn) without using a keyless remote? I really don't like having the horn honk loudly when I come home at night. The manual only lists instructions using the keyless remote (which I don't have). Thanks Quote Link to comment Share on other sites More sharing options...
dssenne Posted March 29, 2013 Author Share Posted March 29, 2013 Well I found the solution to this: I was pressing the small "lock/unlock" toggle switch at the front of the controls. If I lock the door using the lock button that's by the opener on the door - no honking. While I still want to get a couple keyless remotes, this is good till then. Quote Link to comment Share on other sites More sharing options...
brus brother Posted March 29, 2013 Share Posted March 29, 2013 So, you are able to lock the door using the inside switch then close/lock the door? Good way to lock your keys in the car by mistake! I'll have to see if I can do the same on my car. Quote Link to comment Share on other sites More sharing options...
