EastCoastEJ22T Posted March 31, 2013 Share Posted March 31, 2013 I have a '00 EJ25 (SOHC non-egr) from a BH outback that has been completelyrebuilt on hand in the shop. I just picked up a '03 BH legacy (SOHC + egr) with a pretty strong noise inthe engine, either piston slap or immanent tensioner failure.I rebuilt the '00 EJ25 planning on swapping it into a VW Vanagaon, this isa long term project that won't be on the road until 2014....... hopefully. So rather then pull the '03 EJ25 and doing a rushed R&R, I would like to justdrill and tap the EGR port into the '00 outback engine and swap it intothe '03. Then I can rebuild the '03 at my leisure and use it in the vanwhen the time comes.So aside from the EGR stuff is there anything else that needs to be changed over from one long block to theother? I read somewhere to swap the cam and crank gears, not sure why exactly since both are phase2 SOHC 2.5's.Anyway any input or advise would be appreciated. Link to comment Share on other sites More sharing options...
lmdew Posted April 1, 2013 Share Posted April 1, 2013 Take a look at the crank gear, if they are the same on both cars you will be OK. Larry Link to comment Share on other sites More sharing options...
ocei77 Posted April 1, 2013 Share Posted April 1, 2013 On 4/1/2013 at 1:22 AM, lmdew said: Take a look at the crank gear, if they are the same on both cars you will be OK. Larry They changed. Looking at them side by side you'll see. O. Link to comment Share on other sites More sharing options...
johnceggleston Posted April 1, 2013 Share Posted April 1, 2013 if you use the 03 intake with the EGR on the 01 block and heads you will have to replace that equipment once the 03 is ready to install next year. did you find the write up on the drill and tap of the head? Link to comment Share on other sites More sharing options...
EastCoastEJ22T Posted April 1, 2013 Author Share Posted April 1, 2013 (edited) I did find the thread on the EGR drill and tap. Looks pretty straight forward, I work as a aircraft maintainence engineer and pretty much just drill holes in aluminum for a living. I might spin up a few drill stops on the lathe to fit the drill bits to manage - control hole depth. Edited April 1, 2013 by EastCoastEJ22T Link to comment Share on other sites More sharing options...
EastCoastEJ22T Posted April 1, 2013 Author Share Posted April 1, 2013 On 4/1/2013 at 10:42 AM, johnceggleston said: if you use the 03 intake with the EGR on the 01 block and heads you will have to replace that equipment once the 03 is ready to install next year. Could I not just freshen up the `03 long block & plug the EGR port. Then run it off the `00 harness, cam & crank sensor sprockets, intake manifold and ecu. It`s basically the reverse of what I am doing to the `03. BTW I have the complete `00 outback on hand. Plus I have a few other subaru engines available (Ej22t, EG33, and a EJ25 DOHC etc.) but I want to run a newer EJ25 sohc in the vanagon. Got hpétq numbers and better fuel economy and reliabilty. I love my EG33 swap but it is a absolute pig on fuel. Link to comment Share on other sites More sharing options...
johnceggleston Posted April 1, 2013 Share Posted April 1, 2013 yes, just plug the hole and go. i forgot you were using it else where. Link to comment Share on other sites More sharing options...
